Oil overfilled. should I drain?
Old Oct 1, 2009 | 09:12 AM
mule3010's Avatar
I just got my truck back from the dealer for the lift pump to in tank conversion. While my truck was ther they chhanged the oil. I should have checked the oil before I left but I didn't. It is at least 2" over on the dipstick. I always put in a qt and a 1/2 less than it calls for and that puts me right on the top of the full mark. Do you think my dipstick is off? will 2 qt.s over hurt anything?
Thanks
Mule
Old Oct 1, 2009 | 09:21 AM
CamperAndy's Avatar
I will go with your dip stick being off unless you have a real big dent in the bottom of your oil pan.
My 06 calls for 12 quarts and it is a hair under the full mark.
Old Oct 1, 2009 | 09:38 AM
mule3010's Avatar
12qt.s has always put me a couple inches or so over.
Old Oct 1, 2009 | 09:41 AM
MikeyB's Avatar
Mine is slightly over the full mark with 12 qts. Cummins calls out for 12 qts (with filter) so I go by that, and not the dipstick.
MikeyB
Old Oct 1, 2009 | 09:42 AM
Danavilla's Avatar
I had my oil changed twice at the selling dealer. Each time, they overfilled by a qt. I ultimately concluded that they filled the filter when installing and then added 12 qt.. It was still slightly overfull when I next changed it myself. A total of 12 quarts brought it to the full mark.
A letter to the dealer about it was unanswered.
Old Oct 1, 2009 | 09:43 AM
055055.9's Avatar
Mine is right on @ 12 qts
Old Oct 1, 2009 | 09:50 AM
psd1's Avatar
Mine too.
Old Oct 1, 2009 | 11:02 AM
NJMurvin's Avatar
I had this happen to me recently. Dealer overfilled and it came out the overflow on my brother-in-law's driveway (not cool). He said, "Hey, your truck is leaking!". I said, "Can't be. It has never leaked." There was a small puddle (couple of inches in diameter). I blamed it on someone else because my truck has never leaked before. Then, I remembered that I had the oil changed at the dealer recently. Sure enough, the dipstick showed it was overfilled (although I don't recall how much over it was). I posted here and everyone said to leave it alone. A few days later, no drips. I wouldn't worry about it.
Old Oct 1, 2009 | 11:05 AM
Fiftygrit's Avatar
I always put in 11 quarts and then fill the oil filter and shes real close.
Old Oct 1, 2009 | 06:16 PM
trik396's Avatar
A couple INCHES over??? That makes no sense at all... You sure you have a Cummins under the hood??? Or maybe someone swapped out your dipstick and now you have the wrong one?
Old Oct 1, 2009 | 06:20 PM
bansh-eman's Avatar
If you do infact have more il than needed, be careful. Too much oil can not only blow your seals, it can cause the crank to slap the oil and foam up making it near impossible for the pump to distribute the oil properly. This goes for all motors.
Old Oct 1, 2009 | 08:14 PM
Mocho's Avatar
Always 12 qt here to. Fill the filter with one of them of course. Puts it pretty high on safe, but not over. You'd think the dealer would go by the book and put a total of 12 qts in but I doubt it. Everytime my dad gets his oil changed, it's overfull, when I bought my truck the dealer had the oil changed, it was overfull to. Doesn't really care, if something happens it's their problem. The one time they got it right, was because they left the drain plug loose and it leaked, was down over 2 qts by the time it was back to the dealer
Old Oct 2, 2009 | 05:40 AM
BLACKBEAR's Avatar
I had a dealer that put 4 gal in. They said that they check the air filter and i did not need one.So when i went back i told them i wanted the air filter check they said they did it the day before. I said show me anyway. they showed me.Boy did the service manger get a big let down the filter was dirty.I had him look for some hand or fimgers prints before they check it.He said the man lied to him.I said fire the lying -----
Old Oct 2, 2009 | 02:25 PM
Pull Ya's Avatar
Mocho
I think if the dealer overfilled my truck I'd care. It might be their problem if something happened but with my luck the problem would happen when I was a thousand miles from nowhere, with no cell coverage and on Sunday. You bet I'd care---
Jay
Old Oct 2, 2009 | 04:49 PM
15 Digger's Avatar
With 2 inch level kit my 06 took 13 quarts with filter to full mark.
