Oil Fume smell?
Old Sep 19, 2006 | 08:16 PM
EQUIPPRO's Avatar
Oil Fume smell?
Does anybody notice the smell of oil fumes near the front of the cab. I know, i know, it is a diesel, however, the reason i liked the Ram so much was that when i bought it I did not notice the smell of oil fumes in or near the cab like my powerstroke. It got so bad with my Ford that at a red light I had to put the windows up sometimes. It turned out to be a cracked y pipe but the smell was always around, just not as strong. I have not had this prob thru the first 30k miles. I did put O'reillys brand of 15w-40 of ci4+ rated oil in at the last change. They told me it was bottled for them from Shell and same as rottella T. Has anybody had this problem of strong oil fumes by simply changing oil brand. I think this may be the cause, but it just doesn't make sense. Also I seem to have a little oil spot underneath that comes from the blow-by tube under the engine. is this normal???
Old Sep 19, 2006 | 08:31 PM
Gunrunner's Avatar
rotella smells a little after an oil change
Old Sep 19, 2006 | 08:34 PM
1stdodge's Avatar
Oddly enough...yes, I have had the same problem with Rotella in my Dodge.
The exhaust is very strong, and easily gets into the cab.
It smells like a land-fill.
I always used Rotella in my Ford Powerstroke, but it never smelled any different.
In my Dodge it does.
After a 1000 miles or so, it gets better.
Old Sep 19, 2006 | 08:40 PM
EQUIPPRO's Avatar
Thanks Matt & 1st. I thought i was crazy. I have put 3200 miles since last oil change for a total of 32,500 and the smell is still noticable if standing next to the front of the truck. I used the Rottella T for the first 30k miles and no smell. Now that I used O'reillys brand, bam; now a smell.
Old Sep 20, 2006 | 08:34 AM
mattk50's Avatar
i get the same thing with delo 400.clears up after a couple hundred miles.
Old Sep 20, 2006 | 11:44 AM
elirandolph's Avatar
i get the same exact thing with delo or amsoil. I finally goes away after 1000 miles or so. I wouldn't worry.
Eli
Old Sep 20, 2006 | 07:33 PM
RAMROD2006's Avatar
Easy fix
Yeah it is frequently referred to rosmella.
You can extend your blowby tube under the cab and it will take care of the problem.
goatjr
42
May 22, 2010 03:49 PM
jaroban
14
Dec 22, 2006 09:16 AM
eightball
Apr 6, 2006 08:30 PM
Lil Dog
49
Feb 5, 2005 11:22 PM
