Oil Filters
Old Sep 27, 2009 | 04:19 PM
Undertaker's Avatar
Oil Filters
With so many different brands of oil filters. What oil filter is the best for the dodge cummins and why? I am not sure what to use. Thanks
Old Sep 27, 2009 | 04:54 PM
DirtEater's Avatar
Most of us tend to prefer the LF 16035 Stratopore filter from Fleetguard/Cummins Filtration. They're about $13 or so, and are a step up from the Mopar filter which is a rebadged Fleetgurad, but not their higher end Stratopore.
Geno's a is a good online source, but you can also get them at any local Cummins service center.
http://www.genosgarage.com/prodinfo.asp?number=LF16035
Old Sep 27, 2009 | 04:56 PM
DirtEater's Avatar
Another filter would be the Amsoil/Donaldson Ea080 but they're high dollar.
Old Sep 27, 2009 | 05:35 PM
Dr.Dizzle's Avatar
I run the Donaldson Endurance Synteq ELF 7349. This is a synthetic media filter. From a data sheet: Donaldson® Endurance™ filters are 98.7 percent efficient when faced with 15 micron contaminants,and they are 50 percent efficient when faced with seven micron contaminants. I have researched this product and feel that it is better at trapping more dirt, provides better filtration and extended life than the Fleetguard Stratapores that I used previously. Albeit, a very good choice as well.
Why, you ask? It gives me a warm fuzzy feeling inside.
Last edited by Dr.Dizzle; Sep 28, 2009 at 03:20 AM. Reason: Additional information provided
Old Sep 27, 2009 | 07:41 PM
carl48's Avatar
the lf 16035 fits them all and filters best
Old Sep 27, 2009 | 10:39 PM
PCM's Avatar
PCM
Originally Posted by Dr.Dizzle
I run the Donaldson Endurance ELF 7349. It is a synthetic media filter, which I believe is rated at 15 micron. Why, you ask? It gives me a warm fuzzy feeling inside.
ditto!
Plus, the FS-2500 bypass system
Old Sep 28, 2009 | 04:16 AM
TexasCTD's Avatar
Just changed my oil again today.....and put another LF 16035 Fleetguard on it, like I always have. 120K. I just buy a bunch at once from Genos too.
Old Sep 28, 2009 | 08:28 AM
TonyB's Avatar
Since my first oil change, I've ran the Stratopore LF16035 and change oil at the recommended 7500 miles. Oil analysis at 7500 has ALWAYS come back saying that I can continue to run the oil. Soot and metals are always VERY low.
Tony
Old Sep 28, 2009 | 10:57 AM
neversatisfied's Avatar
TonyB
What type of oil do you use?
Thanks Steve
Old Sep 30, 2009 | 10:46 PM
TonyB's Avatar
Steve,
I'm running Valvoline Premium Blue, 15W40.
Tony
Old Sep 30, 2009 | 11:06 PM
rockcrawler304's Avatar
I have run Fleetgaurd since new except for the last change I did. I did not notice I was out of filters until I was about to change the oil and had to run to the dealer for a Mopar filter. I will be placing my usual order of 4 filters from Geno's again soon.
My extra 2cents is, DO NOT USE a Fram filter. Search here and you will see why.
Old Oct 1, 2009 | 06:57 AM
MikeyB's Avatar
I use Fleetguard or Baldwins.
MikeyB
Old Oct 1, 2009 | 09:54 AM
055055.9's Avatar
Me Too
Old Oct 1, 2009 | 09:59 AM
psd1's Avatar
I use the NAPA gold (wix), got my last batch for $4.99 each at the big NAPA Filter sale.
Old Oct 1, 2009 | 11:52 AM
DirtEater's Avatar
Are the Napa Gold filters using anything like synthetic material? I'm wondering what separates the Gold from their 2 lower lines.
