Oil Change Overfill
Old Dec 26, 2005 | 06:47 PM
Toto's Avatar
Oil Change Overfill
Hi Guys
I had my oil changed at the dealership the other day, and the idiots overfilled it by about 2.5 litres.
I drove it home about 12 miles dicovered the problem and drove it back to the dealer to drain the oil and refill.
Did not appear to be foaming and sounded alright.
Should I be worried?
2004 305 555 Cummins.
Holds 11.4 litres with the filter...had about 14 litres in it for about 25 miles.
My brother in law who rebuilds car engines said that with an engine as big as the Cummins , a couple of extra quarts is no big deal, and probably would not have caused a problem of foaming?
Old Dec 26, 2005 | 07:30 PM
rjm022's Avatar
if you had that much oil for such a short period of time- you should be ok. but i would of got it documented at the dealer-just to be on the safe side.
Old Dec 26, 2005 | 07:41 PM
Geico266's Avatar
Not to worry. It's the long term effect of overfilling that is the problem. I've run mine a quart over for 7,000 miles cause I was too lazy to drain out a quart. You just get more coming out the blow by tube.
Old Dec 27, 2005 | 08:34 AM
nickleinonen's Avatar
no worries... that just gives you another excuse to get off the couch [or other favorite chair] and do your own oil changes.
Old Dec 27, 2005 | 12:35 PM
Toto's Avatar
Thanx for the help guys!
Put my mind at ease....the truck is running fine.
woodsman
Oct 16, 2007 10:39 PM
BlackSunShyne
Aug 8, 2005 06:25 PM
JMc
Dec 10, 2004 09:56 AM
GeorgiaCracker
17
Jan 19, 2004 08:53 PM
moondog
Dec 4, 2002 07:50 PM
