Oil Overfill
Old Oct 16, 2007 | 09:11 PM
woodsman's Avatar
Oil Overfill
I accidently overfilled the oil in my 6.7 by about 1/2 gal. Do you think I should drain the excess or is it OK to run it that way? Comments welcome.
Old Oct 16, 2007 | 10:04 PM
nickg's Avatar
drain it down, some engines can be overfilled and the crank will not pass thru the oil, some engines, for example a 85 Toyota 4x4 22re engine if overfilled by 1.5 quarts will barely maintain 60 mph (even at the best of times its a struggle) its because it robs power from the engine to force the crank throws thru the oil in the crankcase. over filling (to a point) will not cause seals to pop (another myth)
Old Oct 16, 2007 | 10:12 PM
psd tuner's Avatar
i would drain it...yeah its a hassel but having too much oil is like having too little, thats what i always been told and to me it make sence. every one of my trucks and tractors are a 1/4-1/2 over to allow for loss from seepage exc.
Old Oct 16, 2007 | 10:19 PM
JSPulliam21's Avatar
I would drain it to reach the proper level. Too much is bad, just like too little.
Old Oct 16, 2007 | 10:39 PM
woodsman's Avatar
Thanks
It looks like a consensus. Thanks for the help guys. Down the drain it goes.
Toto
Dec 27, 2005 12:35 PM
BlackSunShyne
Aug 8, 2005 06:25 PM
JMc
Dec 10, 2004 09:56 AM
GeorgiaCracker
17
Jan 19, 2004 08:53 PM
moondog
Dec 4, 2002 07:50 PM
