No start
Old Mar 19, 2020 | 04:49 PM
Pat Donato's Avatar
No start
I have 05 2500 5.9 Cummins and it won't start without starting fluid and it has codes
p2609
P0335
P0336
P0088
I just replaced the relays for grid heater.
Any help would be appreciated.
Thanks
Old Mar 19, 2020 | 08:14 PM
SAVOY1964's Avatar
Don't know if this helps.P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0088 Fuel Rail/System Pressure - Too High
P2609 Intake Air Heater System Performance
Read more at https://www.obd-codes.com/trouble_codes/
Old Mar 20, 2020 | 10:12 AM
FMB's Avatar
FMB
Originally Posted by Pat Donato
I have 05 2500 5.9 Cummins and it won't start without starting fluid . . .
Be careful with the starting fluid unless you have disconnected your grid heater. If you don't, you engine may start if you are lucky, but if you aren't lucky, there may be a bright flash of light along with a loud noise along with parts of the intake side of your engine flying across the yard. Not fun. Disconnect your grid heater prior to using starting fluid.
Back to morning brew . . .
Old Apr 24, 2020 | 12:43 AM
Green_Machine's Avatar
Crank sensor can cause no start. It's an easy change. Check for damage to the sensor-Mine was damaged by god knows what-probably debris of some type.
If that doesn't help, check rail pressure---If low it's injector troubleshooting time. If you don't have a rail pressure guage you can clip a voltmeter into the signal wire-0.5V = 0 psi, 5V= 20000+psi
I got about 2.5V (IE: Definatly above the pressure threshold for firing the injectors) when cranking while I had a no start condition-turned out to be the crank sensor.
Chay
tim lowman
Dec 10, 2016 12:54 AM
jetbt25
25
Mar 16, 2009 09:05 PM
curts99
27
Feb 25, 2009 09:26 PM
DodgemnLeavem
Nov 12, 2007 12:16 PM
joker834
Feb 12, 2007 05:09 AM
