no start , 2003
Old Dec 30, 2011 | 07:29 PM
butch2000's Avatar
no start , 2003
Hi , my 2003 Cummins truck won't start when it gets cold , I checked the power at the heating grid with a test light , and there is no power there when the wait to start light is on ? where does this feed from ? I checked the the junction box and there is no listing for this ?
Old Dec 30, 2011 | 08:33 PM
madhat's Avatar
Administrator/Jarhead
How cold is it there? The heater grids will not come on unless it is colder than 55*F. The indicator light will come on every time you turn the key on, tho.
Old Dec 30, 2011 | 08:35 PM
madhat's Avatar
I have been watching videos of Cummins starting at 20 below... you could have injector problems or ring problems.
The grid heater relay is controlled by the ECM. The relay is over by the passenger side battery, you should see the cables running to it from the batteries and to the heater around the front of the head.
If you need more info, let me know.
Old Dec 31, 2011 | 10:07 AM
butch2000's Avatar
no start
well it has been frosty mornings , so it sould be cold enough , what are the symptoms for injectors ? it does not smoke ? but it is lazy ? fuel pressure is good , and the rail pressure's are in range ?
Old Dec 31, 2011 | 01:31 PM
madhat's Avatar
Hard start when cold, white smoke on start up.
It could also be your rail pressure sensor.
My advice: Start with the cheapest stuff first.
Do you have any codes?
When you say the rail pressure is in range, do you mean that when you are cranking it, or when it is running?
What is it doing, exactly?
Old Jan 1, 2012 | 03:06 PM
butch2000's Avatar
no start
well , when it gets colder out it won't start . plug the block heater in and it will , good all day , it just cranks over next morning , fuel pressure is 10 psi , rail is 6000 to 8000 when cranking ,
Old Jan 4, 2012 | 04:06 PM
DBLR's Avatar
Injectors is my best guess based on every 03 that has the same no start if not plugged in problem, but will start if plugged in.
Old Jan 9, 2012 | 01:23 PM
beagles4ever's Avatar
Hey guys my first time to reply to this forum. brand new member hope iam doing this right. I also have a 2003 3500 with the same problem. Just started this winter with the cold start problem. if i cycle the key about 5 times it will start, but has to crank for a while. hope this will help the guy with the same problem. also I have done the lift pump volume check and made sure the intake grid heaters are working. I have come to the conclusion that if you have the original inj. pump and injectors its time to replace both
Jimmy RockAway
Oct 5, 2009 09:12 AM
CoolumConst
Oct 11, 2008 10:00 PM
BILL DODGE2003
Apr 19, 2004 04:01 PM
BILL DODGE2003
Apr 19, 2004 08:51 AM
shortround
Aug 22, 2003 02:50 PM
