No spin front end guys in here plz
Old May 23, 2013 | 09:12 PM
trik396's Avatar
I have Dynatrac front end for about 30,000 miles now problem free but never have regreased a unit on our trucks before. Anyone have a link to a write up about doing this? Is there a special size socket for nuts? I assume its a big one. I'd like to do this in next few weeks and want to prepare. Thanks
Old May 24, 2013 | 06:38 PM
SlowJeep's Avatar
What is your question? How to grease the bearings? Did you install the kit yourself?
The spindle nut socket is a standard Dana 60 socket like this...
Powerbuilt 648477 Spindle Nut Socket 1 Ton, Four Inner - Amazon.com Powerbuilt 648477 Spindle Nut Socket 1 Ton, Four Inner - Amazon.com
Old May 24, 2013 | 07:34 PM
trik396's Avatar
I haven't done wheel bearing since the 80's on my 1970 Chevelle. So I'm rusty in the memory department. On Dynatrac sight they mention a six point OTC spanner so should I get that or the four pointer you mention? Also how do I get bearings out of races? From there I think I can handle the rest.
Thanks
Old May 24, 2013 | 08:48 PM
SlowJeep's Avatar
Well, call Dynatrac to see what spindle nut they use but it should be a standard Dana 60 one like I posted.
As far as the bearing repack, etc, it's just like all Dana 44 or Dana 60 front ends from like 1968-1998+ depending on what vehicle. You have lockouts and spindle nuts to remove, and an inner and outer bearing to remove and repack. To get the inner bearing out you'll have to remove the inner seal, pull the bearing out, repack it, and put a new seal in.
Call Dynatrac, they should give you all the part numbers and tools needed for the job.
Old May 27, 2013 | 01:02 AM
Camp10's Avatar
Thanks
I installed my dynatrac assembly with the 6-point spanner nuts for the outer spindle, and I used the recommended OTC #7090-A spanner socket.
O.fO.shO
Nov 18, 2005 07:28 AM
Capt'n Ron
Oct 7, 2005 09:45 AM
Gordonville
Apr 18, 2005 09:45 AM
Nevada
Dec 28, 2002 11:47 PM
