New Radiator
Old Jan 30, 2011 | 05:18 PM
bobsallyh's Avatar
Question New Radiator
Anybody replace their radiator on an '03? If so where did you get it? Thanks.
Old Jan 30, 2011 | 05:51 PM
tryNto's Avatar
Haven't had to replace on current Truck, But I have always done well with Radiators from Pep Boys...
Old Feb 1, 2011 | 02:28 PM
kry226's Avatar
Late... but I replaced mine on my 04. Picked it up from a local dealer, but he said there were 300 on backorder nationwide.
Old Feb 23, 2011 | 07:24 PM
RCND's Avatar
Looks like its leaking
Howdy all
Looks like the rad. on my Dads truck is leaking. Its an '03 3500 automatic dually 4x4 SLT.
I gave it a quick look and it looks like its leaking at the tank seam. I would like too know how many rows and if trans cooler is in tank (didnt think to look when there), and good place to get a replacement that fits properly and is not too spendy.
Thanks
Robert
Old Feb 24, 2011 | 04:39 AM
RHC's Avatar
RHC
Try here https://www.radiatorbarn.com/
Old Feb 24, 2011 | 10:00 AM
CD in NM's Avatar
LMC truck has them too.
CD
Old Feb 24, 2011 | 05:17 PM
heavyhauler03's Avatar
Talking radiator
i am southpointe radiator i'll give you the best deal i can
open from 8-5 eastern time
located in downriver michigan by the airport
call 734-941-1460
Old Feb 27, 2011 | 08:13 PM
bobsallyh's Avatar
Smile Rad repaired
Here is what happened. Pulled rad out and it was wet from bottom towards top for about 5". Took it to rad repair shop and the guy fixed it. Told me when I picked it up to check "that there is something rubbing core where I patched it". Sure enough, I laid both sections of fan shroud on the rad and the bottom section where there is a molded indentation for the wires going to the fan, that indentation was rubbing core. Sort of acts like a "conduit" for the wire. I simply sawed out the indentation. Re-installed rad and good to go. This is on an '03. I checked out my neighbors, one is a 2004 and the other is a 2005. Those 2 have a completely different fan shroud set-up.
8liter
Sep 22, 2012 10:19 AM
jiMMyCTD
May 30, 2005 10:12 AM
Mcmopar
Mar 16, 2005 02:05 PM
awmasparky
Jul 19, 2003 10:41 PM
