new to dtr and need advice with fuel issue
Help!
2004 Dodge 3500 4wd, 136,xxx miles, auto, K&N air filter and intake, straight thru exhaust, FASS lift pump, add on water separator after FASS, and Bully Dog plug in programmer set on “tow”. Usually use Lucas, Standyne, or Power Service additive.
Never had any real issues with the motor until yesterday. Pulling empty gooseneck trailer, rolled up to stoplight, and felt like the motor had high idle. 10 seconds with foot on brake, the tone of the motor changed and started rolling black smoke. Didn’t know what to do, so I put in neutral, and RPM jumps to 1500 rpm and then immediately comes back down.
Went down the road ok (a little more smoke than usual), idles in park and neutral ok, but in any gear with foot on brake after about 10 seconds equal same problem as above.
No codes other than one Bully dog says (PE062ecm?) will show up- means nothing according to them. Cleaned out that code & put back to stock-same issues and no codes. Do not see fuel in oil (not a significant amount/no growing).
Any ideas? Thanks in advance!
What is “average” life expectancy for injectors?
Welcome. Could be a sticking FCA (fuel control actuator) on the CP3 injection pump. You could try some 2 stroke oil in a tank of fuel (TC-3 ashless) to see if it unsticks. Not a real $$ part or that hard to replace either. Or maybe a bad throttle position sensor. IF you just have an extra water separator and no additional fuel filtration you might have some tired worn injectors but doesnt sound like the symptoms. Get a 2mic fuel filter and ditch that K&N air filter.
None of the local parts stores know what this is, and Dodge dealer says this is part of the pump-not serviced seperately. Is this a Cummins part, or do I have to go to an authorized pump repair shop? Also went to the auto parts store, and they have "low ash" but no "ashless" tc-3 oil. Same thing?
Dodge tells you it's a non-serviceable part because they want you to purchase the whole $1000 pump. Find a local authorized Cummins dealer....they have them. Also, www.genosgarage.com has them.
Update to my issue from earlier post: sprage (sp) in torque converter messed up. Updated to Goerend billet input shaft, 3 disk t.q. and valve body. Works like a champ-ought to for what it cost!
Thanks for the insight.
Glad you got it fixed. The FCA would have been tons cheaper than a full tranny for sure but now that you've got that fixed you have room to grow.
dan123dbl
Feb 13, 2015 05:47 PM
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
rbrettctd
Nov 1, 2007 04:11 PM
wap
24
Jun 1, 2007 06:09 PM
