Need help diagnosing a vibration....
Old Nov 28, 2011 | 02:05 PM
DodgeChallenger's Avatar
Us short box guys do not have the carrier bearing issue!
Old Dec 1, 2011 | 11:18 AM
BLACKBEAR's Avatar
Originally Posted by papaduck
I'm not saying that it is not a u-joint, but check the harmonic balancer on the front of the crank shaft. It is supposed to be checked every 30k miles. Check for the rubber splitting and separating and make sure the 2 marks are opposite each other and aligned on the inner and outer steel parts.
They have a fluid one that is a lot better than the one on there. I have seen a lot of good reports on them,
Old Dec 1, 2011 | 02:27 PM
papaduck's Avatar
I have been looking to replace mine with a fluid harmonic balancer. Just haven't wanted to turn loose of the $500 to get one.
Old Dec 10, 2011 | 08:47 AM
iweb's Avatar
Originally Posted by smartin1
Just went through this also. But I had 150k miles. Replaced the 3 u joints on the front shaft, still had the vibration. Had done the ball joints and wheel joints last year. Then replaced the 3 rear u joints. The center u joint was rusted and nearly froze up. But the real issue was the carrier bearing. It was nearly frozen up. It can not be lubricated. While the rear drive shaft is out, you must replace the carrier bearing. Its essential. But don't pay $200 for the dealer bearing. NAPA has it and I found the part # on this forum. Its NAPA bearing HB88508 and I paid $67.49 for it. NAPA counter said they couldn't get the carrier bearing. Give them the part # and they'll have it. So now I have all 6 drive shaft bearings with grease fittings and a new carrier bearing. Should be good for 100k-150k miles hopefully. If you lose a new u joint prematurely, its because of bad install or a cheap bearing. Pay up for good u joints, and use a bearing press or vice. The vibration was making me crazy till I got it solved. Good luck.
Napa told me the part number for the carrier bearing is HB88530 and it is $151.00 for my 05. Any ideas why the different number and price?
justagoodolboy
Apr 24, 2009 09:13 AM
roxxx
Jan 14, 2009 01:53 PM
Sunir
Feb 5, 2008 02:58 PM
KBennett
Jul 30, 2007 06:55 PM
Hoss
Jan 3, 2007 11:38 AM
