Need bolt torque for NV 5600 to motor
Old Oct 1, 2008 | 06:37 PM
Valv's Avatar
Anybody knows what's the torque for the bolts from transmission/bellhousing to engine ?
Thanks
Old Oct 1, 2008 | 06:48 PM
madhat's Avatar
Administrator/Jarhead
16) Install the bolts to hold the shift tower to the
isolator plate and the transmission case. Tighten the
shift tower bolts to 10.2-11.25 N·m (7.5-8.3 ft. lbs.).
TORQUE SPECIFICATIONS
DESCRIPTION N·m Ft. Lbs. In. Lbs.
Plug, Crossover Cam and Detent 48 35 -
Bolt, Input Retainer 28 20 -
Bolt, 5-6 Crossover Bracket 28 20 -
Bolt, Clutch Housing 48 35 -
Bolt, Extension/Adapter Housing 48 35 -
Bolt, Shift Tower 9 7 80
Switch, Back-up Lamp 28 20 -
Bolt, Shift Blocker 55 41 -
Bolt, PTO Cover 40 30 -
Pivot, Clutch Release Lever 22 16 -
Plug, Fill 30 22 -
Nut, Output Shaft 339 250 -
This is all I have...
Old Oct 1, 2008 | 08:38 PM
Valv's Avatar
That's more than enough, my manual covers the G56 but not the NV5600.
Thank you very much
svanni
Mar 24, 2008 03:53 PM
Jimminyc
Oct 14, 2007 06:52 PM
mainer
Jul 17, 2007 07:13 PM
blacksmoker
Oct 9, 2006 12:55 AM
ataboy9026
Jan 14, 2006 07:54 AM
