Mystery Miss
Old Nov 1, 2011 | 02:51 PM
Haynsling's Avatar
Mystery Miss
Started with a major miss at idle and no power when i give it some throttle. Put it on the scan tool and got #1 and # 5 injectors not firing. Changed all injectors... same problem but code changed to #4 injector not firing. Warrantied the injector put the new ( reman) injector in... same problem and code. Changed injector pump and lift pump... same problem same code. Found out the injection pump was faulty... warrantied that... same miss but no codes. Heres where it gets interesting. Hook up the snap on solus and individually dissable the injectors... #1 no change, #2 no change, #3 idle gets smoother when dissabled???, #4-6 idle gets rougher when dissabled. i checked all the wiring... seems to be in good condition(havent checked continuity at every connection and yes im avoiding the dredded short search). Checked valve lash, and compression... all good. no smoke of anykind nor is the oil level changing. I and just about every diesel mechanic i know are stummped. Please help!! Thanks
Old Nov 1, 2011 | 03:35 PM
Colo_River_Ram's Avatar
With age comes the cage
Welcome to our forum and sorry for your problems. Take some time and fill out your sig line for future posts here is a tutorial on that:
https://www.dieseltruckresource.com/...e-t224825.html
As for you miss you might try reading this thread:
https://www.dieseltruckresource.com/...t=shorted+wire
Old Nov 2, 2011 | 12:04 PM
Haynsling's Avatar
Btw its a 2003 HPCR with no modifications at all
Old Nov 2, 2011 | 12:22 PM
Spooler's Avatar
Sounds like you have a bad injector wiring harness that is built into the valve cover gasket.
Old Nov 4, 2011 | 03:19 PM
Haynsling's Avatar
checked wrirng through head... continuity is good on all 6. reinspected the wires on the a/c compressor and the altenator and they appear to be intact and not damaged??? mechanic is telling me the ECU might be no good... i heard if the ECU is junk then the scan tools wont communicate with it?? is this true? I dont think its wiring but i will continue to scour the engine compartment until i find something. i really want to get her runnin good so i can blow her up myself!!! thanks again for the input
Old Nov 9, 2011 | 06:35 PM
Haynsling's Avatar
So i guess no one wants to help!!?? thanks anyway
Hummin Cummins
Jul 5, 2003 09:55 AM
RamThatStroker
Jun 10, 2003 01:01 PM
Huey
21
May 7, 2003 09:57 PM
RATTLINRAM
30
Dec 7, 2002 09:26 PM
Jbolt001
Oct 27, 2002 06:50 AM
