My 48re is eating govenor pressure solenoids
Old Mar 18, 2009 | 09:51 PM
  #46
bchesley's Avatar
Ahh, now I get it. I will do that tomorrow.
Old Mar 24, 2009 | 11:11 AM
  #47
bchesley's Avatar
Ok. I finally had a chance to check this and I am not really sure if I have the right tool to do the job. I have a little Analog Multimeter that has DC settings and AC settings. The AC settings are 10, 50, 250, and 500. I set it at ten and touched the leads to the battery and it pegged out. I set it at 50 and it went to 35. I took the lead off of the passenger side battery that goes to the alternator and re checked it and it went to 30. I am not sure I did anything contructive by checking this because I am not sure the Meter I have will do what I need.
Still confused!
Old Mar 24, 2009 | 06:50 PM
  #48
badme's Avatar
Still confused!
I am thinking that you have to unhook the alternator wire or it will back feed.
30 is way to much ac voltage. Unhook the alternator and check it again. If you still have doubts go to a reputable garage and ask them to check the charging system for a/c voltage. They should know what you are talking about, if they do not run to a better garage. Ask how much they will charge to do this, I would think $20.00 or less.
Old Apr 13, 2009 | 06:12 PM
  #49
yellowhemi's Avatar
Originally Posted by no_6_oh_no
What accessories? If you are grounded gound, not overtaxing the electrical system, and have now scuff wires that sounds far fetched.
For a heavier duty solution here is the only one I have found.
Who sells that kit?
Old Apr 13, 2009 | 06:18 PM
  #50
no_6_oh_no's Avatar
PATC, about 3/4 way down the page.
http://www.transmissioncenter.net/dodge.htm
Old Apr 13, 2009 | 06:19 PM
  #51
xtoyz17's Avatar
Search for #REC and it will go down to it (Ctrl+F).
Shawn
Old Apr 13, 2009 | 06:32 PM
  #52
yellowhemi's Avatar
Thanks for the site.
Old Sep 17, 2021 | 09:54 AM
  #53
dynamicent's Avatar
km
ACTUAL CAUSE OF MULTIPLE GOVERNOR SOLINOID FALURES:
Since the early 727s Dodge has had a problem with the rear sprag mounted in the transmission case.
The problem is that it is pressed into the case, not bolted or even knurled.
Under high torque applications it comes loose and drags against the clutch drum next to it.
It wasn't a major problem until the electric solonoids were added.
The rubbing of sprag against the drum creates very fine metal powder so fine it gets past the filter.
This powder gets stuck to the magnets in the gov solinoid and jambs it open.
It is possible to use carb cleaner and a battery to clean some of the powder out, but it won't get it all and the solinoid will jamb up again.
The only REAL solution is to replace the rear sprag with a bolt-in unit.
OT-OF-Here
Apr 16, 2009 02:03 PM
Equipment man
Jan 16, 2006 04:38 PM
turbo6justin
Oct 6, 2004 09:57 PM
