Mpg help
Old Jan 16, 2007 | 11:54 PM
nitis's Avatar
which tranny you got? if you have the g56 that could be a culprit
Old Jan 17, 2007 | 12:10 PM
sickandtwisted's Avatar
I've got the 48re...
Old Jan 17, 2007 | 08:39 PM
nitis's Avatar
how hard to you run it keep it at 2k you should be ok dont push 22-24 even though it is easy to do
Old Jan 17, 2007 | 08:48 PM
I try to run under 2k most the time, but I hop up on it once in awhile. A couple of times I have consistantly driven slower and less aggressive to see if it would pan out to more MPG. It seem like 13 Mpg either way though.
Old Jan 17, 2007 | 10:07 PM
blb4742's Avatar
When the weather is nice I will kill the motor, roll the windows down and make my girl get out and push. My milage goes way up then.
Old Jan 18, 2007 | 02:14 AM
Must be a big girl
Old Jan 18, 2007 | 08:37 PM
ppsi's Avatar
I get 18 at least. Mine is 2X4 though so I think there is an increase there. I also suggest a huge air filter. I have a homemade setup using some pipe I got online and a giant filter. It cut EGT by 100 too! I also misplaced my muffler-never had a cat and my tip goes out in front of my rear tire so no rear axle hump. Amsoil in everything too.
Old Jan 19, 2007 | 05:25 AM
Kman9090's Avatar
Lose low end by removing the cat, I've never heard that before. But with my 06 on crazy larry i get about 21mpg on freeway and about 19 city if i can keep from layin the hammer down. My bro has an 05 with and edge juice and he gets about the same maybe a little better.
Old Jan 19, 2007 | 12:58 PM
Yeah, I was told if I lose the cat, the muffler, and have it it turn out before the wheel well I'd lose my low end I really didn't figure it to be true but I guess why take a chance
Old Jan 19, 2007 | 02:10 PM
DBLR's Avatar
I don't think it would be a good idea to remove the cat being you live in CA they may frown big time on the removal of it.
I hope they delete this as i see your in Canada not CA
Old Jan 19, 2007 | 02:59 PM
iflych52's Avatar
My last few tanks I was at around 9-10 mpg. All city,cold outside,idle time to warm up truck, and winter blend fuel. I did hit 19.6 last fall on a Hwy trip.
Old Jan 19, 2007 | 03:08 PM
No, you're right Ca is for California...Ehh!
Old Jan 20, 2007 | 07:37 PM
Todays fuel ticket 413 miles on 26.98 gallons = around 15.3 mpg
Mostly all highway driving @ 70mph & 2k rpm's
Old Jan 21, 2007 | 06:33 AM
SupaDupa's Avatar
Air up your tires. Keep at least 75psi in the front. You can get away with a bit less in the rear, but I keep 75psi around as I tow 4-5 days a week. My best highway mileage is 21.2 running a steady 65mph for almost 500 miles. 50/50 combo suburban driving (empty and towing) I get 16-17 usually. This past tank I was driving "HARD" and I got only 15mpg. That tank was mostly towing, a lot of short trips and COLD over night temps.
Old Jan 21, 2007 | 12:44 PM
What is it that you are driving?
