Milage - To TSB or not?
Old Nov 26, 2004 | 08:19 PM
  #31
Rod_Montana's Avatar
In my case, neither truck sounded any different. The idle in both is still around 700-750. We are both running Winter Diesel #2.
Neither "white smokes" at all.
Your build date is less than a month before mine. Same rear end, but my drive train is box-stock, except for the wheels.
Old Nov 28, 2004 | 07:51 PM
  #33
eastmentCTD600's Avatar
So what does one need to tell the dealer to get the TSB?
Thanks,
Eric
Old Nov 29, 2004 | 04:56 PM
  #35
6 Inline's Avatar
Originally posted by wildbillnc
I had this done when it first came out loved it at first then noticed that my truck didn,t seem to have the same low end torque as before and I only gained about 1MPG but the over head is consistantly off byt 2 MPG now it does take a lot longer to warm up and the engine rattles and pings a lot more all the time but it is worse when it is cold I would not recondmend thisTSB any longer it is not worth the loss of power and only proof that DC is playing it's cuctomers for fools but it must be working for them because I seem to be the only one that sees this !
There has been more than 1 tsb for this service. Are you sure you got the latest? Might be worth a trip back to the dealer. Or maybe a different dealer.
The reflash really worked for my truck. The pinging went away and fuel econ went up. Hope you get it ironed out.
Old Nov 29, 2004 | 07:16 PM
  #36
Texcowboy9's Avatar
The flash worked for me too. I guess that makes me another one of Dodge's "fools".
Old Dec 1, 2004 | 01:36 PM
  #37
pinging gone away after TSB?
You say the pinging went away? Correct me if I'm wrong but is the "pinging" you describe heard at light engine load, part throttle, under mild acceleration and sounds semi-erratic (many posts on this topic)?
If so, has anyone else who had this TSB performed and had the pinging/knocking noise noticed its absence after the TSB?
Thanks in advance.
Eric
Old Dec 1, 2004 | 01:41 PM
  #38
HdPower's Avatar
I supposedly had TSB done still pings & knocks. But mileage improved.
Old Dec 1, 2004 | 01:48 PM
  #39
Hand calculated, overhead computer #'s, or both?
By the way keep the responses rolling in for the pinging issue!
Eric
Old Dec 1, 2004 | 03:57 PM
  #40
HdPower's Avatar
Hand calculated on the mileage, the computer is off about 1 mpg difference.
Old Dec 1, 2004 | 03:59 PM
  #41
KeithSmith13's Avatar
I went in today to have the reflash doen and they told me it was not available for the 05's yet. However they did enable the high idle but it only goes up one time to 1200rpm is this normal?
Old Dec 1, 2004 | 05:57 PM
  #42
From the TSB 18-004-04, which is incorporated into TSB 18-037-04 (http://dodgeram.info/tsb/2004/18-004-04.htm)
"...Once enabled the feature operates as follows:
With the vehicle stationary and the gearshift lever in Park or Neutral, press the speed control “ON/OFF” switch to the “ON” position.
Press the “SET” switch. The engine speed will automatically increase to 1100 rpm.
The engine speed may be increased up to a maximum of 1500 rpm by pressing and holding the “ACCEL” switch.
The engine speed can be lowered down to 1100 rpm by pressing and holding the “COAST” switch ."...
So try this procedure.
Eric
Old Dec 1, 2004 | 06:57 PM
  #43
spudman's Avatar
the pinging is gone with the exception of accelerating past about 50 mph
Old Dec 1, 2004 | 08:14 PM
  #44
T & T's Avatar
are you kidding me? F'ing ******* charged me for this feature and it turns out it's a TSB??? Now I'm really p'd off.
Smokin96_12v
Jan 21, 2010 01:06 PM
Dually Driver
13
Nov 13, 2007 09:10 PM
twhman
27
Jul 16, 2006 11:36 AM
Adieselbrother
Mar 21, 2005 03:27 PM
t-15 firefighter
14
Oct 22, 2004 10:10 AM
