map sensor question
Old Oct 23, 2007 | 01:26 PM
Rpainter's Avatar
map sensor question
I had to remove my quad race box due to it not working well with a triple dog and now I have no boost fooler but am running 50 psi of boost without a high boost or overboost code.If a map sensor goes bad will it throw a cel or not??
Old Oct 23, 2007 | 02:41 PM
bob4x4's Avatar
Not very often.............
Bob
Old Oct 23, 2007 | 03:11 PM
RamWheelsBy4's Avatar
When you intalled the Silver Bullet turbo did you install the jumper on the electronic wastegate wiring harness?
If so then maybe the Bully Dog is doing some boost remapping (fooling) like the Smarty does now.
Old Oct 23, 2007 | 05:26 PM
Rpainter's Avatar
yes made my own jumper
Old Oct 24, 2007 | 04:14 AM
Dodgezilla's Avatar
With the resistor in place I can make around 40psi before throwing the overboost codes if I pull my boost fooler off.....
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
