mag-hytec rear diff cover
Old Dec 11, 2008 | 06:23 PM
mike moore's Avatar
just installed my rear diff mag-hytec cover.very nice product,quality stainless bolts,cover is very heavy-duty.the craftsmanship is professional.Used about 7 quarts of lucas 75/140 synthetic,and 9 oz of limited slip additive.truck has 15,000 miles on it.I want to do the front but dont know if my carli lift,w/fox steering stabilizer,and trac bar will interfere with a front cover from mag-hytec.have to do some research.if anyone is on the fence about doing your covers in mag-hytec,do it,you wont be dissapointed.
Old Dec 11, 2008 | 06:29 PM
DNRCustoms's Avatar
I did mine a yr ago.. Very good product..
Old Dec 11, 2008 | 08:02 PM
bradler's Avatar
I thought you weren't supposed to add limited slip additive....
Old Dec 11, 2008 | 08:51 PM
Country23047's Avatar
Uses Amsoil 75W-110 when I put on my Mag-Hytec. No additive necessary.
Old Dec 11, 2008 | 08:55 PM
J.Suplanski's Avatar
Talking Mag tech
My front mag hy tech would not work when Carli installed my suspension with the dual stabilzers etc etc
bradler's Avatar
Just wanted to make sure the additive is not necessary. I also filled the rear with the amsoil SG 75w-110, good stuff.
Old Dec 11, 2008 | 10:44 PM
dslpwr81's Avatar
No additive.
Old Dec 12, 2008 | 01:49 AM
snoyes's Avatar
I put Amsoil 75W-90 in mine, no additive needed. Some discussion on here that guys with the heavier weight oils needing it to prevent the limited slip from acting up when in sharps turns, especially when pulling heavy trailers.
I put the front one on and with my 4.5 inch Tough country lift I have a slight contact in the top corner of the cover... Not sure I'm going to keep it on their, may go back to stock. Quality product, just wish they would re-design the front one slightly to prevent this type of clearance issue. I've heard guys that have shaved the area I have contact with to prevent contact after talking to Mag-Hytec. Also, supposedly Mag-Hytec redesigned the front diffs in the past year or so to make it fit better, but I have the newer one and it still contacts...
Old Dec 12, 2008 | 04:11 AM
TexasCTD's Avatar
Of course...........you could just run a MH on the rear diff.......and a PML on the front.
Old Dec 12, 2008 | 04:32 AM
snoyes's Avatar
I know, just didn't want to waste the front now that I have my little notch in the Mag Hytec. But the thought has crossed my mind....
Old Dec 13, 2008 | 06:49 AM
PZM123's Avatar
No additive. I'm using Amsoil 75 / 140. Is that the cover with a dip stick?
Old Dec 13, 2008 | 06:56 AM
Hvytrkmech's Avatar
I put mine on a couple years ago, filled with Lubrication Engineers 80/90.
Yes the cover has a magnetic dipstick on it.
Tim
Old Dec 14, 2008 | 12:13 AM
Highway 4x4's Avatar
The reason you don't need any friction modifier in our diffs is because there are no clutches in our possi units. They are a worm gear type spyder. Check out the True-Track units by Detroit for a better exp.
Old Dec 14, 2008 | 10:51 AM
mike moore's Avatar
dodge claims the 11.5 inch rears require additive.its certainly not going to hurt or contaminate the oil if you use it and its not needed.lucas oil also claims no additive needed when you use their synthetic fluid,but again,its no big deal to just add the additive,costs like12 bucks for 9 0z.I figure i will give carli a call to see if they can give me a definative answer on wether their 3 inch lift will rub a mag-hytec front cover before i spend the money on it.
Old Dec 14, 2008 | 11:50 AM
AH64ID's Avatar
You're not...
Actually, they say to not use it, in bold letters in the owners manual. The additive is added on clutch style LSD's, the OE in the AAM is a helical gear setup...
