Made a discovery on my NV5600
Old Dec 12, 2007 | 06:06 PM
  #31
mhenon's Avatar
You can try this:http://www.turbodieselregister.com/f...synchro-s.html
Mike
Old Dec 12, 2007 | 06:35 PM
  #32
laramie5.9's Avatar
I read the link you posted and it pretty much said the same thing I suggested and throw in some posi additive. I guess I pulled one out of my **** on that one!
Old Dec 12, 2007 | 06:52 PM
  #33
steelblitzkrieg's Avatar
DTR Detective
I have to be honest I haven't driven a Cummins with a stick, but why can't you ignore the clutch and just match RPM's? Too hard to pull out of gear and match or what? I know completely different animal, but that's how I drive my Mustang and she's got 154k on her factory clutch.
Old Dec 12, 2007 | 07:58 PM
  #34
C Schomer's Avatar
The Synchromax is "recommended for manuals that require either atf, multi-vis or straight grade motor oil and is fully compatible with all types of friction materials without affecting the soft metals in synchros". It's similar to the oem lube weight. A lot of napas sell RP but I was in a Checker on Monday and saw they started selling it now. Craig
Old Dec 12, 2007 | 08:11 PM
  #35
OLD94's Avatar
My tranny was hard shifting until I took Joe Donnelly's advice and used Torco RTF. 30k miles and it shifts smooth and easy even on cold days. Shifts to reverse are easy too.
I fill mine to the factory fill hole. Donnelly suggests that over filling MAY cause leakage onto the clutch.
Joe
Old Dec 12, 2007 | 08:53 PM
  #36
stock600's Avatar
Thanks mike for that info, that was some good reading! Ive done nothing but factory oil in mine since new, and will continue prob. with the addition to i will add the FM and give it a try. Mine always has been just ok, but since the fe clutch its noticable worse.
Old Dec 12, 2007 | 10:15 PM
  #37
Homer S.'s Avatar
I've got 40k on mine, shifts fine, probably time for a change anyway.
Old Dec 19, 2007 | 09:48 AM
  #38
PEAKSTRYDE's Avatar
It has been about 10K now since I switched to REDLINE MTL, and I'm ready to try something new! I will sadly say that the factory fluid made shifting almost 2X easier
Has anyone tried adding the LUCAS additive????????
This tranny is the worst, stiffest shifting tranny I have driven
Old Dec 19, 2007 | 11:18 AM
  #39
Hounddog's Avatar
According to the tests and comments I read a long time ago LUCAS oil/lube additives is I'm suprised that the REDLINE MTL did not make you happy.I have been very pleased with the Amsoil in mine.The EXTRA Qt through the top PTO cover bolt hole made a noticeable improvement also.I did the extra Qt.many moons later.Don't get me wrong,it still shifts as bad as 4 on the column in a 1960s Fiat but thats as good as it gets.
Old Dec 19, 2007 | 04:16 PM
  #40
PEAKSTRYDE's Avatar
Originally Posted by Hounddog
According to the tests and comments I read a long time ago LUCAS oil/lube additives is I'm suprised that the REDLINE MTL did not make you happy.I have been very plweased with the Amsoil in mine.The EXTRA Qt through the top PTO cover bolt hole made a noticeable improvement also.I did the extra Qt.many moons later.Don't get me wrong,it still shifts as bad as 4 on the column in a 1960s Fiat but thats as good as it gets.
THANKS HOUNDDOG,
I'm on my way home to throw 1 more QT in through the top right now!!!!!!!!
88bird
Oct 27, 2005 01:22 AM
DieselDaze
Jul 30, 2004 09:06 AM
Dave65
Feb 3, 2004 08:01 PM
AKDSLDOG
Nov 7, 2003 07:55 PM
patriot pearl blue
Dec 17, 2002 09:39 AM
