Lube for the rear end
Old Jul 21, 2004 | 09:28 PM
Mark Thomas's Avatar
So if I order the Amsoil 75w 90 with the gl5 additive would that be alright or would 75w 140 be a better choice or does it really matter?
Old Jul 21, 2004 | 10:04 PM
Jeff in TD's Avatar
I'm running redline 75-140... The dealer suggested the heavier weight for towing.
Old Jul 21, 2004 | 11:50 PM
durango12's Avatar
fluids for diff
is there any reason people dont use the factory synthetic fluid in there diffs or trans? i have allways used it i know it is exspensive but i work for a dodge dealer and have a supply of 75-140 and 75-90 synthetic in the garage so it doesnt cost me much . i read a post were american axles reccomend 75-90 synthetic and i know dodge tells us to put 75-140 synthetic in them when we service or repair them.
d12
Old Jul 22, 2004 | 05:25 AM
drb-600's Avatar
I need to do my rear end this weekend - approaching 16K on the clock - can anyone tell me where I can find this Redline stuff in or around Houston?
Old Jul 22, 2004 | 07:09 AM
LRAmberson's Avatar
Mark, No additive is required. This is clearly stated in the owners manual. The rear end is not a cluch setup from what I learned in earlier discussion( I do read these things with coffee )& as informed on the thread this was confirmed by a rep with AAM..
As for the fluid weight the manual does recommend the lower thickness but if you tow heavy it's up to you if thicker is better.
I am running the 75/90 just for warrenty reason.
Old Jul 22, 2004 | 08:28 AM
Jeff in TD's Avatar
durango12, I don't have a problem with the DC synthetic, it was just that the Redline synthetic has a good reputation and was cheaper...
drb-600, I actually bought my Redline at the Dodge dealership because I needed it right away, but I'm sure you could get a better price from one of the mail order places.
LRAmberson, At least according to the parts guy at my dealership, 75-140 will not void warranty, as long as it is full synthetic that meets GL-5.
Old Jul 22, 2004 | 11:14 AM
1sttruck's Avatar
I used Mobil 1 75W-90 in both axles. Relatively easy to find, works good. Concerns I've heard about Redline are that it's possibly not the best oil for extended intervals, especially if exposed to water, in spite of it being well liked on the track.
Old Jul 22, 2004 | 05:51 PM
Yup I know that, I was just wondering will it hurt?
Old Jul 22, 2004 | 09:57 PM
AaronT's Avatar
Thumbs up
My 04.5 specifies 75-90 synthetic front and rear diffs.
Off topic, I checked all fluid levels after picking my truck up and all levels were correct.
Old Jul 23, 2004 | 07:14 AM
MikeyB's Avatar
I'm about to service the rear end on mine. My local auto parts store carries Lucas 75w-90 synthetic gear lube. Is this stuff any good? The parts man recommended Lucas for my truck.
MikeyB
Old Jul 26, 2004 | 05:50 PM
silver_goat's Avatar
I like the Royal Purple full synthetic. It is a bit pricey ($9 qt.) but comes in 75/140. Most others I have seen are either 75/90 or 90/140. It is a GL-5 lube.
Old Jul 26, 2004 | 07:42 PM
Tfeore's Avatar
The Mopar oil is EXPENSIVE(My parts guy wanted 32/qt) and you know it's just someone elses oil with their label...
The dealerships all use Redline('round here anyway) when it's not a warranty issue. If DC's paying they use Mopar oil.
I just put in AMSOIL 75/140 at $12/qt & as stated before you don't need the additive, I do feel as if I just bought from Amway though...
Old Jul 26, 2004 | 08:44 PM
Hannibal's Avatar
You did... I swears I don't see the attraction to Amsoil. How is it better and why isn't it API certified?
Old Jul 27, 2004 | 07:13 AM
MikeyB's Avatar
May check into Royal Purple. The auto parts store wanted $12 a quart for the Lucas.
MikeyB
Old Jul 27, 2004 | 11:24 AM
SuperGewl's Avatar
[B]
DON"T use the 75/140 it will mess up your rearend. The AAM axels state use 75/90 ONLY
Axels DO NOT REQUIRE any limited slip oil additive(friction modifiers)
So whatever yo do don't do it don't do it don't do it
