Lube on fuel filter cap ??
Old Jan 20, 2010 | 02:47 PM
msiminoff's Avatar
My fuel filter cap is difficult to remove... even after breaking it loose with the socket, it's hard to turn. I always coat the o-ring with fuel when I change the filter but I have never used any other lubricant on the threads or o-ring.
Does anybody else use anything on the cap or o-ring other than diesel fuel?
Thanx
-Mark
Old Jan 20, 2010 | 03:06 PM
nelrod's Avatar
I use fuel too.
Old Jan 20, 2010 | 03:13 PM
Dr.Dizzle's Avatar
After cleaning the cap and threads I use fuel as well.
Old Jan 20, 2010 | 08:42 PM
GreyTD's Avatar
I have always used clean oil. ULSD is not very lubricating on the o-ring IMO.
Old Jan 21, 2010 | 08:08 AM
Al Ex's Avatar
I've always used a little Vaseline on the threads. Not sure if this is bad, but no problems I'm aware of with 78K miles now.
Old Jan 21, 2010 | 08:24 AM
AlCorr's Avatar
I always wet my fingers with motor oil (because I change the fuel filter when doing oil change) and rub the oil all around the O-ring before putting it on the cover, works for me. I've never used fuel.
Old Jan 21, 2010 | 10:03 AM
MikeyB's Avatar
Motor oil.
MikeyB
Old Jan 21, 2010 | 11:48 AM
msiminoff's Avatar
Looks like quite a few have been using motor oil...
I change both filters at the same time too, so I'll give that a shot at the next change.
Thank you!!
Old Jan 21, 2010 | 12:05 PM
carbuff415's Avatar
I have some O-ring lubricant which is a lot like Vaseline. I have also used motor oil prior to having the O ring lube available. Both products seems to yield the same result though.
Old Jan 21, 2010 | 12:14 PM
AlCorr's Avatar
Originally Posted by MikeyB
Motor oil.
MikeyB
Yes, very little, only enough to wet one finger and my thumb, then I pull the rubber O-ring between the two wet fingers, puts a fine coat of oil on it. Then pop it onto the cover. It never leaks.
Old Jan 21, 2010 | 05:27 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
I use fuel and a wrench, it's always pretty tight but never an isue.
Old Jan 21, 2010 | 05:34 PM
bonus's Avatar
motor oil x2
Old Jan 21, 2010 | 05:47 PM
carpenterje's Avatar
petroleum jelly or same as vaseline
Old Jan 21, 2010 | 06:28 PM
NickBeek's Avatar
Engine oil. Put some on the threads as well. It makes it much easier to do it.
mknittle
Mar 11, 2015 10:47 AM
dssimecek
Mar 10, 2008 04:58 PM
VFDFireman
Jan 5, 2008 06:47 PM
sterling
Oct 19, 2007 05:32 PM
ajpulley
Jan 16, 2006 04:21 PM
