Engine Flush
Old Jan 21, 2010 | 10:37 AM
grandblanc's Avatar
Engine Flush
Any thoughts on doing an engine flush using, Amsoil Engine Flush (AEF)? I'm switching from conv. oil to full sysn. amsoil and I'm just wondering if doing a flush is going to cause any issues. I know people don't recco. a trans fluid flush, just wondering if the same goes for engine oil.
thanks in advance.
Old Jan 21, 2010 | 10:45 AM
John Faughn's Avatar
I would say that the flush may be excessive , the Amsoil with blend with conventional oil just fine .
I have seen oil analysis that maybe , excess breaking free with changing oils , but after the first change , it may not be an issue .
I am a fan of flushing , the vast majority of trany fluid is left in the rest of the trans. , vs. just dropping the pan , its a waste to put 1/4-1/3 of the volume , new oil to old .
Old Jan 21, 2010 | 11:36 AM
Sevir's Avatar
when i switch to full syn, i just changed my oil at regular intervals for a year (twice) then switched to my extended oil change. hundreds of people switched to syn without doing a flush, you will be fine the traditional way
Old Jan 21, 2010 | 07:07 PM
grandblanc's Avatar
thanks. just got done doing the change over. just ran it and got it good and hot, then pulled the plug and let it drain for an hour. i'll do an analysis at my next change to see what's going on in there.
CACalomino
16
Mar 22, 2010 06:35 PM
Sam Turner2
Nov 18, 2008 10:17 AM
grantx5
Jan 5, 2008 06:56 AM
LFD2037
Nov 8, 2006 09:12 PM
Dieseldude4x4
Sep 7, 2003 08:06 PM
