Loud "Clank" under truck when parked
Old Nov 7, 2014 | 09:36 PM
Calgary's Avatar
05 Laramie crew cab 5.9C yada yada...
When parked after driving home from anywhere, really.
After about 30 seconds I hear a loud Clank coming from under the engine area.
not climbing under to look as I'm afraid of what I'll find. After about a minute or 2 I hear another. This will go on for several minutes. Not the typical cooling down sounds but a very startling "CLANK"!
Anyone else experience this issue? What the heck is it??
Tried searching but all that comes up is tranny issues or something else that's happening when a person is driving. This happens when the truck it parked and off.
Old Nov 9, 2014 | 09:29 AM
railroaderone's Avatar
Had there been any coolant loss/ or had it been changed before this started. happening ??
Old Nov 15, 2014 | 10:06 AM
Calgary's Avatar
I had a belt tensioner failure that required a coolant change when it was discovered the water pump was almost shot and changed.
I never noticed if the clank was there before this repair was done.
But there has been no coolant loss since the repair.
Is it related?
Old Nov 21, 2014 | 11:42 AM
Sawyer1's Avatar
Probably the exhaust cooling down. Mine makes a loud noise that you can hear over the truck running at an idle and after it is shut off.
Old Nov 21, 2014 | 02:10 PM
I would check and see if you had an air pocket trapped. Losen one of the pipe plugs on the head and see if any coolant ooses out.
Mick-e
Sep 4, 2012 06:18 PM
threepin73
Jul 10, 2010 04:16 PM
AmadosWorker
Jan 22, 2008 12:53 AM
mysterystench
Sep 30, 2007 03:45 AM
Turbo Deeezle
Oct 7, 2004 05:31 PM
