Looks like I have a Problem
I got into an accident about a month ago.
Just got the truck back. Everything was fine when I dorve it home. I didn't floor it though. This morning on my way to work i hit it pretty good. I am hearing a whistle or something only when I get on it. When I'm just driving normal it doesn't do it. Could it be the intake or something with the plumbing? It sounds like something isn't connected all the way. I looked at the intake and it looks like it is fine. i will take a better look at it when I get home. Can you please give me places to look. Thx.
If you dont find anything in the intercooler lines and intake, look at your boot guage tube. Got my truck back from the shop one day and had a it had a whistle all the way home, look at my boost guage under full throtle I had no boost, get home pop the hood and found the tube just folded back under acouple other wires.
JW
JW
Well I got home and checked all connections. All connections seemed fine. Checked for cracks and didn't see any. Took truck for a drive, and its still there. It seems it is coming from the air vents, like a whowl or something. It is pretty loud when you get on it. Any suggestions? They did replace the AC condenser if that helps any. Thanks again.
I agree, It might be a pain to take it in, but the longer you wait the more likely they will say it's not their problem!
The only problem with taking it in to where i got it fixed is that they know nothing about diesels and performance. They are just a body shop. I rather bring it to a place that knows alittle bit about both. It sounds like it coming from in the dash area. It happens when I reach 10PSI and above. It sounds like when you take air out of a balloon slowly. I'm starting to think its one of the guages. Can it be either the boost or the EGT, or just the boost? I'm not loosing any power and the boost guage is still working. Thanks.
Maybe they just damaged your boost guage tube somewhere along its route? If the sounds is coming from the inside under boost, did you check the small tube inside the cab for bends or cuts?
I remember someone else having an exhaust leak that whistled like you describe also. I cannot remember if it was a crack or just leaking by the gasket but it did whistle.
tslewisz
Jul 15, 2011 07:33 AM
sheriffav8r
May 29, 2008 06:47 PM
