Longer Starts
Old Jun 3, 2008 | 09:57 PM
75bronco's Avatar
Longer Starts
My '06 5.9 seems to crank a while before it fires. Not all the time, once in a while. Im running the edge and its not showing any problems. Is this something to be concerned about or not. Its spiratic and sometimes its cold and sometimes it may be all warmed up.
Old Jun 3, 2008 | 10:25 PM
SpLaT's Avatar
Nothing to be cncerned about, its just the computer trying to determine where its at in the timing/firing order. Closer to the timing/fire order means less cranking time, farther away equals longer cranking time.
Old Jun 4, 2008 | 01:58 AM
chipmonk's Avatar
there is a long crank tsb, with a re-flash that sometimes helps. it can also be an injector leaking down- for lots of people, the long crank issue was the first sign of one or more bad injectors.
Old Jun 4, 2008 | 09:21 AM
Bigsmoke3500's Avatar
Wouldnt if the injectors were leaking then there would be fuel in the oil? i have the same problem once and a while. when mine does it, usually it lets out a small puff of while smoke when it starts. nothing crazy just a little puff. ive had many problems with injectors. the dealer had to replace 5 out of the 6 injectors due to cracking or leaking, and every time there was fuel in the oil. maybe its time to just get a set of DDP's!
Old Jun 4, 2008 | 02:17 PM
chipmonk's Avatar
i had 2 injectors that were leaking down, and before they were replaced, i never had any fuel in my oil (as far as i could tell). imo, your cranking issue combined with the white smoke, sounds like it might be time to have that 6th injector changed out.
Old Jun 4, 2008 | 03:59 PM
SpLaT's Avatar
75bronco... hope these guys aren't scarin ya... as you described its sporadic, mine does the samething, its by no means injectors. If you have a leaking injector you'll notice an increase of oil on the dipstick or excessive smoke! Or you may notice a "knock". If your not experiencing any of these systoms, I'd say like mine its normal, goes with the computer controlled injection sequence.
Old Jun 4, 2008 | 05:04 PM
chipmonk's Avatar
according to cummins and dodge, they see lots of injectors on the CR's leaking down, and the long crank problem (sometimes combined with slight white smoke, especially on start up) is frequently the only symptom, and was all i was getting, when 2 of my injectors were bad. fuel in the crank case is something you will usually see if you have a cracked injector body or an injector stuck open, but may not be noticeable if you're only having some slight leaking down issues. i'm not trying to scare 75bronco, but the '04.5+ CR's are notorious for injector problems (ball seat erosion and needle side loading), and i know lots of people who have had at least one replaced. if still under warranty, i would definitely have the dealer test them.
97catintenn
Jan 7, 2010 11:33 PM
routerguy99
18
Jun 30, 2003 02:23 PM
Apr 28, 2003 05:20 PM
Stamey
Apr 20, 2003 10:44 AM
