Long Cranking Hot
Old Jun 17, 2009 | 09:50 PM
Kenworth's Avatar
Long Cranking Hot
A friend of mine just bought an '05 and has noticed a couple of things. First, he says it takes quite a long time to start after it's been running for a while. He says if he leaves it for 30 or so minutes or more it starts right up after only a couple of seconds. Could something be wrong with his truck? Or is this normal for a third gen?
Also, he says there is a slight miss/hesitation when he's just below 2000 rpm in 4th gear and he gives it a bit more fuel. I'm not sure if this would be related to the starting thing or not. Any ideas?
Old Jun 17, 2009 | 10:24 PM
thebestofindica's Avatar
My 03 does the same thing. I've only owned the truck for a month but this has been the case since I've owned it.
Old Jun 17, 2009 | 10:35 PM
billie's Avatar
Don't have any ideas but my 03 starts in a sec or 2 all the time, never a problem, hot or stone cold (with grids to 30* below). Never felt a hesitation at any time that I remember. 100K miles so far. Every truck is a bit different though.
Old Jun 17, 2009 | 10:42 PM
cody459's Avatar
More than likely an injector issue, or timming issue if its only having long cranking time when hot and having issue's with my timming or cp3 as we speak and is sorta of doing the same thing. When he is cranking when hot does it feel like the starter stumbles on a cylinder then goes back through and fires?
Old Jun 17, 2009 | 11:27 PM
Spooler's Avatar
Simple stuff first. Has he changed the fuel filter and checked the air filter. If not, since he just bought it, I would change them both.
turbopuller5.9L
Aug 17, 2011 02:58 AM
ScotS
Jun 5, 2008 03:04 AM
DL1221
Jul 14, 2006 08:43 AM
JAKE03CTD2500
Jun 14, 2005 12:47 AM
slowmo
Apr 19, 2005 07:48 PM
