a little long but, could really use some tech help.........
#46
here's the latest update.....
Got all my injectors out and here's a pic of #4. I obviously still need to get the head off cause I'm sure there's some nasty damage under there. The red lint is from my rag.
#48
#49
When you pull this engine down and assess what damage you have, as long as the block and crank are in good shape, you can pick up a complete Cummins overhaul kit for around $2.000. Maybe even less if you know someone with a commercial account.
Did you happen to cut open any of your recent oil filters by chance?
Once again good luck, Tim
#50
Thanks for the tip on the overhaul kit. By the time the labor is done with that though..... I'll have spent as much as a new motor costs. If the damage is that bad once I get in there, I'm just gonna put a new motor in it.
#52
#53
#56
#57
#58
I don't know where you guy got this from. The only thing 53 told me so about is what he thought happen.
It's not like I was warned and went out and did what I was warned against. I knew exactly what I was doing by keeping my foot planted. I expected the motor to hold up a little better than it did though.
"I think he was told that elsewhere too?" I was ? Every post I made was to either get info about what happen and/or so others can see what will happen.
#60
Before buying a new engine, I'd pull the head and see if it just hurt the piston. If the cylinder walls are ok, just buy a new piston kit and repair it. Make sure the wrist pin bushing is still ok from all the fuel wash and put it back together. Should be cheaper than a new bullet????
