a little long but, could really use some tech help.........
No oil reappeared but man did it send out the more white smoke I've even seen and oil poured out of the exhaust.
Yes, it's a stock turbo and never saw over 40psi.
This is something someone mentioned at another forum....
If the charger wasn't spinning fast, and drive pressure was going nuts, you could certainly push oil past the compressor. ( into the exhaust ports ) This is how some "runaway diesel" accidents happen.
I think injectors are in addition to the other problems. It would explain the huge white smoke.
oil in the exhaust will smoke WHITE just like an injector it's blue when it burns in the cylinders.....
If I can figure out how to remove the injectors, it may be a while though. Will have to send them out to Don. Know of any good manual online or directions ?
DDP has one but, it sure seemed like a lot more than necessary... or maybe it's not.
That was a costly trip to prove some Highlands boys wrong. Send me an e-mail. The guys next door may have the tools to pull injectors. I give you there number and you can call them tommorrow. You'll want to talk to Shawn Mcgahee. He pretty smart on all diesels. Big and small. Maybe he can help ya out.
Sorry 53. I also have the exhaust manifold off. I couldn't wait any longer for a 13mm SS HTT housing so, my 64/14 will be here tomorrow. I'll install it and my ATS manifold and see what happens.
you could still fire it off without the manifold, if you want to...then you wont dump oil down your brand new turbo if it is engine damage.
it would be loud...but you would know right now if you have engine problems and not just turbo problems....
let us know what you find either way
Well guys... I think the worse that could happen, has.... I don't know for sure though so you tell me please.
Got the new turbo and manifold installed. Completely took apart the exhaust and clean it a good as I could. Drained the oil and changed the filter. The moment of truth.... I crank it up and it runs.
Unfortunately, the oil continues to drain out of the exhaust. The truck runs with a very ruff idle and actually sounds like one of the sled pullers with a lugging turbo. I don't believe my 64/14 will do that...?
I let it run for a while hoping the oil will stop draining but, after 5 minutes it continued.
When I was running it, I idled up and got the turbo spooled. Once it was spooled the rough running idle cleaned up and it seemed ready to rock. Back to idle though it runs rough.
The smoke only looks white and there still a lot of it. My Smarty is telling me cylinder #4 is misfiring... obviously full of oil.
If you don't mind.... what is my next step ? Do these motors have sleeved cylinders ? Did I fry a piston ring and oil is blowing by it ? I'm really shocked at this since most of you guys are running a ton more HP than me. I figured the motor could handle a little more than what I gave it.
Sounds like at the very least you cracked some piston rings, how is the crank vent tube? more than the normal amount of oil dripping from it, or is there no blow by/oil coming from it? With the engine running hold a clean rag over the crank vent tube for a minute or so. Post what you find.
Tim
Tim
Do you mean your smarty is reading a code about #4 injector misfire? Are you sure it is oil dumping out your exhaust and not diesel fuel with soot in it?
Im absolutely no help with diagnostics...but here is a link to an injector install
http://www.glacierdieselpower.com/im...ectInstall.pdf
