A little help with codes
Old Dec 3, 2006 | 08:31 PM
Southern Washer's Avatar
I have an 05 3500 auto 2wd with edge j/a, and this evening while driving, i had a power loss. When i got home checked the codes: p 0514, 2149 and 2146.
Any ideas ????
Old Dec 3, 2006 | 08:36 PM
bigredBCS's Avatar
i jsut made a post about my dads 04.5 throwing 8 codes, none were the same tho, but....
0514-battery temperature sensor performance/rationality
2146-fuel injector group 1 supply voltage circuit
2149- fuel injector group 2 supply voltage circuit
Old Dec 3, 2006 | 08:39 PM
53 willys's Avatar
isn't there a TSB flash for the 0514 code??? I thought I read that some where on here??
Old Dec 3, 2006 | 08:44 PM
do i need to take it in to the dealer, or is this something i can fix myself?
Old Dec 3, 2006 | 08:50 PM
bigredBCS's Avatar
i have no idea, id take it to the dealer jsut to see what they ahve to say
Old Dec 3, 2006 | 09:00 PM
would the injector codes be the reason for power loss ?
Old Dec 3, 2006 | 09:02 PM
bigredBCS's Avatar
i imagine...if injectors can add power i guess they can take it away
Old Dec 3, 2006 | 09:19 PM
would the edge system have anything to do with it as far as connections go ?
Old Dec 3, 2006 | 09:29 PM
bigredBCS's Avatar
very possible since it has those three connections on the injector plugs or whatever u call em
Old Dec 3, 2006 | 10:54 PM
53 willys's Avatar
Try disconnecting the Edge and see if it fixes it.
Old Dec 4, 2006 | 12:00 AM
Swamp_Donkey's Avatar
My Edge juice was throwing those short circut codes. I had to send it back because my truck would just die. Did this twice and I had enough. Sent it back to edge had it updated and the HOT program installed. I also ran my truck on the stock setting for a couple of weeks and never had a problem with stalling or codes.
Old Dec 4, 2006 | 01:58 AM
how do i reset the codes ?
thinking of pulling the edge j/a out completly
Old Dec 4, 2006 | 10:52 AM
anyone ??????????
Old Dec 4, 2006 | 11:29 AM
53 willys's Avatar
try disconnecting the batteries and turn the key to "start" for a few seconds then just let it sit 5-10 min's and see if they go away.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
oneslowyfz
Apr 20, 2007 12:46 PM
JW3
Mar 15, 2006 08:23 PM
