Limited slip rearend?
Old Nov 24, 2006 | 12:32 PM
sdsaw's Avatar
Have a friend with a 2006 2500 but isn't sure if he has limited slip.
Where does he find this info on the truck? I'm aware he can go to a dealer and run his VIN.
Thanks in advanced
Old Nov 24, 2006 | 12:55 PM
Foxborough's Avatar
A heavy foot and a tight turn will tell you. I can feel the tires (both at the same time) jump around doing that on dry pavement. On wet pavement you can easly feel both tires spin some. Without limited slip I am sure only one wheel would spin.
Old Nov 24, 2006 | 02:22 PM
Spooler's Avatar
If he still has the window sticker it will be an option on it. Maybe he keep it or maybe not. I always keep mine in the glovebox.
Old Nov 24, 2006 | 08:23 PM
skynyrd's Avatar
hold in the brake press down on the go petal and build some boost and do a burn out if you leave one tire mark sorry for your luck, two tire marks you have limited slip
Old Nov 24, 2006 | 09:36 PM
steelblitzkrieg's Avatar
DTR Detective
Jack up the rear end if you have slip when you spin one tire the other will spin the opposite direction IIRC? Someone confirm.
Old Nov 25, 2006 | 01:59 PM
bigdav160's Avatar
No, all open differentials will do this. A well preloaded limited slip will turn both tires the same direction. The TracRite GT gear differential will spin them the opposite direction like an open differential.
Old Nov 25, 2006 | 02:14 PM
Whada's Avatar
Or you could just look at the tag in the gloove compartment.If it doesn,t state anti spin diff ,he dont gots one!
Old Nov 25, 2006 | 02:52 PM
Longhorn06's Avatar
Always looking for an excuse to do a burn out or a real good slide! LOL
In fact I'll go and double-check mine right now....Just in Case! You can never be too careful these days!
Old Nov 25, 2006 | 02:59 PM
DodgemnLeavem's Avatar
NO you can Never be too careful!!!
I must have an OPEN diff. I hardly EVER get two wheel spin.
But I DONT have the glove box sticker?? so where do I look???
I havent really been interested till you guys started talking about it. just knew I must have an OPEN DIFFY. I have an 05 2500 see sig...
thanks in advance.
Old Nov 25, 2006 | 03:04 PM
Longhorn06's Avatar
Sorry, cant help you there! I always save the window sticker, and I always order mine with it, so never had to look. For my conditions (mud and winter) and for pulling it is a must for me! I'm sure someone will know!
Old Nov 25, 2006 | 08:43 PM
XLR8R's Avatar
Determining limited-slip in the AAM axles is deceptively simple:
1. Drive onto wet grass.
2. Stop. (ABS may be checked at this time)
3. Drive off of wet grass. (note - if truck moves off of grass, make sure you don't have it in 4WD; if not - you have an open differential)
4. If you're still trying to drive out of the wet grass, congratulations!
--- You have limited slip!!!
Old Nov 25, 2006 | 09:16 PM
Longhorn06's Avatar
Not trying to be rude....but I'm not following you here at all! I think you have it reversed, or Im not getting what you are saying.
If it drives off the wet grass-you have limited slip...open diff, your likely stuck!
I am short and the joke may have gone over my head though!
Old Nov 25, 2006 | 10:39 PM
Silver76's Avatar
The limited slip on my previous dodges was more likie a limited "grip". Definitely seen better in other trucks.
Old Nov 25, 2006 | 11:17 PM
XLR8R's Avatar
Don't worry, old boy - I'm just engaging in a bit of josh with the blokes who've had the devil of a time using the new AAM Torsen gear-style limited slip differentials...
If you do get stuck in wet grass, apply the emergency brake or the foot brake a bit and you should be out in a jiffy!
If your rear is open, hopefully you have 4WD.
Old Nov 26, 2006 | 12:56 AM
Longhorn06's Avatar
Told ya I was short!! Yep, right over my head!! sorry to add to the confusion!
