Leaking steering gear box
Old Apr 23, 2013 | 08:35 AM
nvr-enuf's Avatar
Hello everyone - I replaced my steering gear box since it was hard to steer. I replaced the gear box with a reman unit which solved the problem. My gear box is now leaking on the top as mounted on the truck - there is a flange with 4 to 6bolts that secure the flange. Seems to be leaking at this flange mounting surface. I did notice when I remove the reservoir cap that a pop sound is made, like it was under pressure or vacuum.
Could this noise be the reason why I am leaking? How do I solve the issue that my reservoir is not venting?
Old Apr 23, 2013 | 01:29 PM
SOhappy's Avatar
Yes, common problem. Search for the "steering box dipstick mod". Basically you disassemble the dip stick and drill a small hole in the cap liner IIRC. Worked for my 2003.
BIGROD
Aug 13, 2008 12:51 PM
bridleman
23
Apr 12, 2008 01:11 AM
unioncreek
Jun 29, 2005 02:00 PM
pwrtripls1
May 30, 2005 09:17 AM
mechanic
Nov 28, 2002 04:13 PM
