leaking CP3!
Old Dec 9, 2009 | 06:55 PM
notblowingsmoke's Avatar
Question leaking CP3!
So I get home tonight after cumming home from the folks house and I pull in the drive and go to plug in the truck because it’s so **** cold here and I can smell raw diesel fuel. So I check under the hood and of all the other places this leak could be coming from, it just happens to be the CP3. So it’s just a little wet underneath and looks as if it’s coming from the thing that looks like it has heat sinks on the back.
My question is I have only 73,000 mi on it and I am the original owner, and in the warranty book it says that this item is covered under Cummins 5yr 100,000mi warranty. Is this the case and has anyone had any problems with dealer doing work. Also is there an easy fix here, can something just be loose and if so what are those items?
Old Dec 9, 2009 | 07:17 PM
no_6_oh_no's Avatar
Thats pretty normal for cold weather and the CP-3. Unless it is just pouirng out in a stream don't worry too much.
I had one replace dunder warranty th efirst winter I had my truck, supposed to be updated CP-3 and all. It leaked the next winter and stopped when things warmed up. Been that way 3 years and 150k with no issues.
Old Dec 9, 2009 | 07:32 PM
dodgediesel's Avatar
Funny thing bud, mine too. Had it at the dealer for 2 days and they can't find the leak. I really don't enjoy cleaning up diesel off my shop floor and the underside of my truck and off the diff cover, etc!! They say it's "normal" to leak when it's cold??? I asked them if it was normal for their bathtub to leak in their house. No response....
I'm so frustrated so I'm trying a different dealer. Leaking fuel is a fire hazard and I think should be a no brainer. Can we sue the dealer if our truck starts on fire. Same dealer told me I didn't have a injector issue. I tested them myself and found #6 to be faulty. Changed it myself. Seems like they don't want to spend any money. I just want this pump to stop leaking. Cheap crap.......................
Old Dec 9, 2009 | 07:59 PM
JJPage's Avatar
That's the gearcase pump assembly on the back of the CP3 that is leaking. It has an o-ring gasket that looks like a large "O" with two small "o"'s on either end.
The gearcase pump is connected to the main CP3 body by four torx screws. If you remove the driver's side inner fender(8 screws), they are easier to access. They may just need to be snugged down. Don't get carried away and snap one off, someone may have the torque specs, can't be much, probably "inch pounds".
Here's a thread you can follow for pictures, it does not show the o-ring, but it shows where it sits in the gearcase pump.
http://www.relentlessdiesel.com/foru...ic.php?f=2&t=5
Old Dec 10, 2009 | 05:05 PM
Update :
Took mine to a different dealer and they found it leaking right away. Going to replace it under warranty.
Tells me something about that first Dodge dealer!!!!!!
Old Dec 10, 2009 | 07:56 PM
1985cucv's Avatar
my buddies 06 just got his replaced under the warranty because it was leaking
Old Dec 10, 2009 | 08:58 PM
rockcrawler304's Avatar
My 06 leaked the first winter and after reading here I did nothing. Has not leaked any more.....yet I will keep an eye on it this winter again though since I am still under warranty for it.
Old Dec 10, 2009 | 10:53 PM
going in...
Well after thinking about it, if it leaks its broken and I am going to make an appointment to get truck in and get it replaced. Nothing should leak on any piece of machinery, something leaked on the shuttle and it exploded.
Old Dec 10, 2009 | 11:01 PM
You got it!!! Especially a flammable liquid. If it leaks, it can't be good.
Old Dec 12, 2009 | 07:28 PM
JJPage's Avatar
Diesel is catagorized as Combustible. But your right, leaking, not good.
Old Dec 12, 2009 | 09:20 PM
Spooler's Avatar
Had mine replaced at 22,000 miles. No leaky since. Supposedly they had a bad batch with seal issues.
Old Jan 9, 2010 | 10:51 PM
All new...
Well took truck in and they ended up replacing all 6 stix and the CP3.
The truck starts a lot better know and no raw fuel smell. All was coverd under warranty.
Old Jan 10, 2010 | 08:23 AM
CamperAndy's Avatar
If your dealer did that with the mods you have then you maybe should play the tables some and see if your luck holds.
Old Jan 10, 2010 | 09:10 PM
Give you a hint...
RETURN EVERYTHING TO STOCK. Problem solved.
Old Jan 11, 2010 | 06:34 AM
CamperAndy's Avatar
So it is okay for you to play and someone else to pay???
