Lamp out with annoying gong
Old Oct 11, 2006 | 02:41 PM
Artcabinets's Avatar
2003 CTD 2500 HO 6spd 114000 miles
Lamp out on dash w/gong . After checking all lights, turn sigs incl. high/low beams, nothing is out ! Who of you can explain this and how can I fix this myself ? I have a faint recall of seeing something in the past about Dodge having problems with the tail lights ???
Thanks, Art
Old Oct 11, 2006 | 03:15 PM
boostjunkie1's Avatar
Thats right!! The back left TailLight is the Demon!!! Check it out and see if the base has been melted. My 03 had the backup light loose and when I would hit a bump the Ding would go off. Just Replace the rear bulbs and it will go away.
Old Oct 11, 2006 | 04:22 PM
expressfish's Avatar
ditto, that style bulb is a pain ! they always seem to melt or the the contacts (wire) on the base of the bulb wear and break/split
Old Oct 11, 2006 | 07:47 PM
Thanks guys for your information. I'll check it out in the morning.
Art
Old Oct 11, 2006 | 09:33 PM
pullin hard's Avatar
i have gone through 2 sets of circuit boards on my tail lights.
i am not sure why, all bulbs are always good, but the sockets they snap into seem to burn, or melt or some thing inside the board. i just replace them and good for another couple hundred miles
Old Oct 11, 2006 | 09:41 PM
RamWheelsBy4's Avatar
Mine did that for about 3 months, I would check all the lights and everything worked, all lights on, brake lights, flashers. One day when I was at the dealer my Service Writer said did you know your left brake light does not work when you are moving. Duh, I could not check them while it was moving. In my case replacing the bulb fixed the problem.
Hoss
21
Dec 3, 2016 02:49 PM
Artcabinets
Oct 8, 2006 03:53 AM
DMH
Jul 27, 2005 06:48 PM
Pickle
Mar 26, 2005 11:57 PM
