Jacobs Brake Issues
Old Apr 27, 2007 | 08:17 PM
NavyChief's Avatar
Angry Jacobs Brake Issues
Allright Boys!!!!
As I left the base today I stopped by the Class 8 (Liquor) store and heard what sound like rattle inside the cab while the truck was cooling down. I listend in the cab, and couldn't quite pin it down, so I opened the drivers door, and the rattle/popping sound became evident as being from under the hood. I thought this can' be good . I opened the hood and realized right away the it was coming from the vacuum pump the powers my Jacobs Brake. I got the truck home, got out the engine stethescope, and sure enough the Vacuum pump is rattling something fierce. The truck only has 39k for mileage so I am even less impressed. Has anyone lese had this issue?
I experienced the joy of removing the 126" serpentine belt and am getting a shorter belt for a non-Jacobs equipped unit in the morning to install. I will be up in Mechanicsburg, Pa for several days next week, and the dealer there will be looking at it. he feels it will be warranty, and it better be. I am hauling my two john Deere Tractors to Ohio around the 31st of May and i want my jacobs back on line for the mountains of PA. Any input is appreciated.
R/
Eric
Old Apr 27, 2007 | 08:23 PM
dws35's Avatar
Good luck, I hope you get it taken care of. I had a problem with a stalk switch after about 15,000 miles on the unit. DC told me that Mopar parts have a 12 month and 12,000 mile warranty and this trumped the warrenty info that came with the unit.
Please post your outcome with this, I would interested in follwoing up on my end if I was treated differently than you.
Good luck
Old Apr 27, 2007 | 08:44 PM
ptgarcia's Avatar
The vacuum pump is expensive. Thats one reason I went with the Pacbrake. If you have to pay for the repair yourself consider the Pacbrake retrofit kit. Who know's, it may save you money.
Old Apr 27, 2007 | 10:37 PM
Jim Dynomite's Avatar
Pauly, the Jake runs off vacuum and the Pac runs off compression right? So is that what the retrofit is for?
............Jim
Old Apr 27, 2007 | 10:53 PM
ptgarcia's Avatar
............Jim
You are correct, the Jacobs is vacuum activated and the PRXB is air activated. I thought Pacbrake offered a kit that converted the vacuum operated brake to a air operated system but I don't see anything on their site. Maybe I dreamed it up!
Old Apr 28, 2007 | 07:33 AM
New York's Avatar
I Think I'm having a vacuum pump issue as well.
I don't have a rattle but I do have a constant hiss, it acts as if it can't hold the pressuse of the exchaust even though my torque converter stays locked.
Old Apr 28, 2007 | 01:00 PM
CrazyCooter's Avatar
I'm planning to use an electric vacume pump off a Ford Super Doody to replace the Jacobs when it bites it.
Should be cheap and easy to get at a salvge yard.
Old Apr 28, 2007 | 01:14 PM
bnold's Avatar
vacuum bad... onboard air good!!
Shilohman
22
Nov 19, 2009 05:13 PM
iflych52
25
Oct 10, 2006 09:25 PM
Apr 2, 2003 12:14 AM
Nevada
Mar 30, 2003 06:24 PM
rkelso98
Mar 14, 2003 06:15 AM
