Intermittent Rough Idle
Old Jun 30, 2007 | 07:56 AM
Jmac's Avatar
Originally Posted by Rpainter
anyone tried cleaning the fca with a good brake cleaner??
What's that?
Old Jun 30, 2007 | 09:39 AM
lanwangeek's Avatar
My 06 has the rough idle at times and I tow a 16K 5th wheel every weekend. It comes and goes for no real reason. After I started putting Lucas Fuel system cleaner/lub in and the rough idle stopped. I filled the tank last week without the lube and the rough idle showed up a couple of days later. But it I put the lube back in, it goes away. I just hoping that I'm not losing a injector. I've got 23000 miles on mine right now. Anthony
Old Jun 30, 2007 | 10:00 AM
53 willys's Avatar
Originally Posted by Jmac
What's that?
FCA=fuel control accuater(sp?)
it's on the back of the CP3
Old Jul 12, 2007 | 02:11 PM
BigHornCTD's Avatar
Any updates about this problem? My truck is going back to the dealer next week for the same problem again (3rd time).
Old Jul 12, 2007 | 05:47 PM
Jmac's Avatar
I'm going to try a new dealership in Leesburg next Thursday. I'm preparing myself now for a lot of hot air up my you know what. That way I won't be as angry when it actually happens.
On a different note I lubed my front drive shaft a couple of days ago and found an oil leak b/w the tranny and the motor oil pan!! Again preparing myself for hot air injection.
Sorry to be so negative but I'm really having a hard time with dealerships giving me the run around lately.
Jamie
Old Jul 13, 2007 | 09:50 PM
Hooligan6's Avatar
I've been dealing with the same thing for months now Its gotten worse then it was, now it does it non-stop.When I take it to the dealer 4-times now they can't find anything wrong with it (big surprise).The RPM drops to 0 then jumps back to just under a 1000.I've pulled and cleaned every wire I can get ahold of and changed many sensors with no affect.I've tried all the additives that have been suggested on this site.I'm at a loss! To date I've spent around $4,000 trying to get this fixed.
Old Jul 18, 2007 | 12:29 AM
BigHornCTD's Avatar
Well I got my truck back today. Since it is a long story, you can read all about it here:
https://www.dieseltruckresource.com/...d.php?t=124162
Old Jul 18, 2007 | 01:44 AM
monnshyne's Avatar
I have a 2006 that was doing the same thing. This truck only got worse in time and had 2 dead cylinders when we figured out what it was. On my 06 it was the A side injector plug not making good contact with the pins. I fixed this by taking a dental pick and pulling the tabs closer in the female side of the plug.
Find a Cummins dealer and buy your valve cover gasket that has all your injector wiring in it. Cummins sells engine parts allot cheaper than Dodge does. Dodge wanted 159 for that and Cummins wanted 110. I still haven't replaced my gasket yet because it runs fine now that I tighten the plug up so it contacts better.
I hope you have a good bit of farming around you. Reason being a dealership will sell more CT trucks in those places so they work on more as well and you have better luck in finding a good diesel mechanic. My problem might not be your problem but at least you know something else to look at. Those 2 plugs need to have dielectric grease in them as well. Hope this helps.
Mark
Old Jul 18, 2007 | 07:33 PM
Jmac's Avatar
Mark
Can you describe the plugs your talking about.
thanks Jamie
Old Jul 24, 2007 | 07:48 AM
monnshyne's Avatar
The plugs that go into your valve cover. It's part your your valve cover gasket and they are much cheaper to buy at a Cummins dealer. Dodge marks up the same parts much much more than Cummins does.
Mark
smokester
May 27, 2011 05:31 PM
Grey Goose
Sep 7, 2010 09:32 PM
NJMurvin
13
Jun 14, 2010 06:19 PM
banks twinram
May 18, 2010 08:10 PM
luf02145
Feb 8, 2008 07:01 AM
