intermittent oil use?
Old Feb 26, 2014 | 07:36 PM
DragonSlayer's Avatar
Arrow intermittent oil use?
Why would my truck use 3-4 quarts of oil every 500 miles, sometimes go 1500+ with no oil consumption? I check the oil 2-3 times a week and only add when it get out of crosshatched area. I do not understand, nor know what to check. I've done everything I know to do / check....... what gives????
Old Feb 28, 2014 | 11:05 PM
I think I'll pull the engine and get a look at the guts of this thing and see what's f'd up. I have a feeling it has something to do with #6 hole being the issue. Seems like #6 is the loser, anyone have any idea why it seems to always be #6?
Old Mar 1, 2014 | 02:28 PM
rockcrawler304's Avatar
There is some good reading here about it but basically #6 seems to get the hottest and has the most issues. Mostly due to the water flow.
Old Mar 2, 2014 | 06:33 PM
Well. I think I'm gonna pull a oil sample before I pull the engine. I'll do a compression test and have the injectors checked. Maybe then I will have more info before I pull it. It's now been over 1300 miles without adding oil.
Old Mar 2, 2014 | 06:44 PM
StealthDiesel's Avatar
Much better plan to gather some info and perform some checks BEFORE pulling the engine.
Old Mar 2, 2014 | 07:52 PM
I'm kinda at a loss as to what to do. So, I'm going to start over with diagnosis. If the truck didn't run perfect, maybe I'd have something to go on.
smokester
May 27, 2011 05:31 PM
Bobcat698
Mar 25, 2008 09:42 AM
bocuso
27
Jan 18, 2007 12:54 PM
themacfive
Nov 9, 2006 08:29 AM
n2topfuel
Jul 2, 2004 08:59 AM
