InMrFixIt
Old Sep 25, 2011 | 03:41 PM
InMrFixIt's Avatar
Thumbs down InMrFixIt
First time posting as I just started working on a 2006 Pickup. Looking for electrical schematics and fuse listing for this pickup. AC quit working clutch not engauging. Tried to check up on line and know I need to check clutch coil and power to compressor relay. I have not found Relays. InMrFixIt
Old Sep 25, 2011 | 03:43 PM
Purplezr2's Avatar
Relays should be under the hood on the left side in the PDC.
Lary Ellis (Top)'s Avatar
Admin Team Leader
Use the search engine here, it is your friend
Old Sep 25, 2011 | 10:34 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Welcome to DTR...
Be a good idea to post you questions in the 3rd gen section....You will get more responds in that section..
Old Sep 27, 2011 | 09:02 AM
InMrFixIt's Avatar
PDC, I will look into this. It must be under the fuses. I have worked on plenty of equipment, but never seen the limited amount of documentation. I downloaded the diagram and fuse listing. I have not found software for my PC to run my USB interface with the OBD-2 adaptor. I can look a a lot of paramaters, but still no access to secondary systems, like A/C. Thanks
Old Sep 27, 2011 | 09:06 AM
InMrFixIt's Avatar
If anyone finds some OBD-2 software for a PC, for diognosing the propriotary systems on a Dodge/Christler/Jeep, this would be helpfull. Thanks again.
Old Sep 27, 2011 | 04:55 PM
gcssr's Avatar
GO to this site and follow the links;;; http://www.dodge.com/bodybuilder/year.pdf
Good luck;;;;;;;;;;;;;
Old Oct 3, 2011 | 01:01 PM
BLACKBEAR's Avatar
What you might do is check the wire close to the pump! It has been known to brake or ground out. GOOD LUCK
