injectors part numbers
Old Dec 30, 2008 | 04:33 PM
pullin hard's Avatar
i have this post in the 07 and up section, so if somebody reads this can you delet that one, wrong section.
what i am looking for is the injector part numbers, from the 03-04 trucks, and the 04.5-07 trucks.
also can anyone tell me the difference between the two cause they sure do look the same. i have a set of cores, in which i thought were for the 03 truck i have, and now i think they are for the newer style, but un sure of the difference. i want to sell them, but i want to make sure i am selling them for the right years of truck, thanks
Old Dec 30, 2008 | 05:09 PM
homewrecker's Avatar
03-04 are 8 hole tips and 04.5-07 are 5 hole.The bodies are the same.For some reason you can run an 03-04 on a newer motor but can't run a newer 5 hole on the 03-04.I know the spray angles are different.
Pm Dwitt on here.He can cover any part number questions you might have as long as you have an engine s/n.
Old Dec 31, 2008 | 12:18 AM
so if the bodies are the same, and some one was buying new tips, or having them done, it wouldn't matter?
just checked mine and they have 8 holes.
Old Dec 31, 2008 | 06:45 AM
If someone was gonna send them off to Don(F1) then it doesn't matter cause he is gonna change the tips over to a 5 hole.Not sure about the other companies.But the bodies are the same and will work in 03-07.
Old Jan 1, 2009 | 02:14 AM
thanks for the info.
sCreamin400
Nov 2, 2008 01:46 PM
psdctd
Feb 2, 2004 06:36 PM
royB
Jul 21, 2003 09:30 AM
KatDiesel
Jun 3, 2003 12:15 AM
MR. GADGET
May 1, 2003 11:24 PM
