Injector failure thread...
Old Apr 25, 2006 | 10:11 AM
trik396's Avatar
I'd like to start a thread to see who has had injector failure, especially in 05's (which I believe are more likely to have this problem).
If there is someway we can gather this info, inorder to see a reoccuring pattern, I'd appreciate your help.
Something like the horsepower thread.
A- Those who've had a failure w/ no mods and no heavy towing
B- Those who've had a failure w/ no mods but very heavy towing
C- Those who've had failure w/ mods (especially pressure boxes) w/ no towing
D- Those who've had failure w/ mods and towing
E- No problems (so far)
Please enter mileage that problems occured and if fix (new injectors) has worked, and what other issues you've had due to the failure (lost turbo, etc.)
I think you guys see where I'm going with this. This problem of injectors cracking or tips breaking off, is unacceptable to me. I haven't had a problem yet, but the thought of it is very worrying.
Everyone, please give their problems without opinions (if possible)
Thanks...
Old Apr 25, 2006 | 10:31 AM
XZILR8N's Avatar
E- No Problems so far. 31,500 miles with about 5k towing, I use Power Service+MMO in my '04.5 religiously. So far, so good!
Just curious, why do you think the 05's are more prone to failure? Did DC change the injector design in the 05's, or some other parameter that would affect injector reliability?
Old Apr 25, 2006 | 10:36 AM
trik396's Avatar
I believe they did change something on the 04.5's or 05's and up. I think it's a different injector with less injection orifices... or something like that...
I'm sure someone with more knowledge about the subject will chime in here.
Old Apr 25, 2006 | 10:52 AM
brk300's Avatar
A....
Have had problems since 5K replaced 1 injector told me all 6 are bad but Dodge wont replace them since my Idle time was too high.
Old Apr 25, 2006 | 11:14 AM
05HDRAM's Avatar
E. No problems at 9k. I use PS/MMO every tank, occassional heavy pulls.
I would not accept the extended idle excuse the dealer is giving. I do not see anything in the owners manual that states you can not idle your truck. I know my idle time is up from sitting in traffic everyday. It's unavoidable.
Old Apr 25, 2006 | 11:38 AM
powerstrokin03's Avatar
D- I have had 7 injectors go out, I have had my crankcase filled with diesel twice. Did compression tests and shes still going fine
Old Apr 25, 2006 | 11:42 AM
whitebuffalo's Avatar
E.-no probs. ~15K miles. maybe 2000 miles towing ~5-6K lbs (knocking on wood and crossing fingers)
Old Apr 25, 2006 | 06:29 PM
610dodge's Avatar
D- around 40,000 in january. #2 and 3 cracked. XZT and quite a bit of heavy towing. commercial BBQ 12 ft pits to louisiana and several loads of 12-16 rolls of hay a few times a week from tyler to dallas.
Old Apr 25, 2006 | 06:32 PM
texaspower19's Avatar
d had an injector drop and filled crank case with diesel
Old Apr 25, 2006 | 06:37 PM
610dodge's Avatar
i filled my crankcase also and it started coming out of the blow-by tube and covered my truck. Tech told me that it gave the inside of the engine a good cleaning and i shouldnt have to worry about anything rusting underneath it for a while with everything soaked in diesel and oil. when i pulled the dipstick it was so clear i almost couldnt see anything at all on it (straight diesel)!!
Old Apr 25, 2006 | 09:01 PM
lmills's Avatar
E. 39,000 miles so far. Had a TST on it with 99 miles on the odometer and twins went on at 12,000 miles.
Old Apr 25, 2006 | 09:18 PM
super_b ak's Avatar
E- light towing and no power mods
Old Apr 25, 2006 | 09:38 PM
AaronT's Avatar
Smile
E: 17,000 miles no problems, no mods, PS, or 10wt about 50% heavy towing.
Old Apr 25, 2006 | 10:25 PM
HdPower's Avatar
D- The most recent one filled the crankcase full of fuel and blew oil/fuel all under the truck all the way to the tailgate, there must have been gallons of fuel in the oil pan, good thing I wasn't towing at the time....mileage was somewhere in the neighborhood of 40K.
Old Apr 26, 2006 | 11:56 AM
staarma's Avatar
E. No problems. Mods in sig. I run it like it is stolen though and have had most mods on since new 0 miles. I have run PS/MMO in tank since about 4000 miles and I have 16000 on it now.
