injector and cp3 tesst
Old Jan 30, 2006 | 02:59 PM
motrapper's Avatar
what test will they run to see where the fuel is coming from in the crank case\
thanks for any ideas
Old Jan 30, 2006 | 03:24 PM
bigblock2stroke's Avatar
I don't think there are any other than visual inspection.
Its either injector bodies cracked or o-ring on the CP3 gear.
I have used dye in the fuel before but you have to use a lot and you have to run the engine with the valve cover off (kind of messy) for the injectors and with the pump gear access cover off of the front geartrain cover.
Old Jan 30, 2006 | 04:06 PM
motrapper's Avatar
now if its and injector wouldnt thier be noise or bad performance something noticable
it goes in tuesday and just nervous about it
adamsmarshall
13
Oct 7, 2008 06:54 PM
Jethro6213
19
Jul 11, 2008 11:59 AM
pullin hard
Mar 18, 2008 03:57 PM
BADBOWTIE
28
Jul 14, 2007 02:36 PM
megacabrule
33
May 10, 2007 01:07 PM
