I'm almost stuck!
Old Sep 8, 2011 | 05:13 PM
cincydiesel's Avatar
Originally Posted by Polaraco
In 04, they were in the tank
Thought the 04.5 were the first ones to get the intank?
Old Sep 8, 2011 | 06:33 PM
Polaraco's Avatar
Old Mopar Aficionado Extraordinaire
I thought so too. But i didn't have a cat. Must have been in the transition period
Old Sep 8, 2011 | 07:59 PM
Creek Diesel's Avatar
I'm almost stuck!
Sounds like Dr. DIZZLE is onto it...Can a man rebuild his own injectors? How specialized is the tooling to do that? I hate to replace all of them if I can rebuild them myself in this economy. How can an individual test the injectors himself? I get that the high psi will wear away a path or "wash out" the injector.
Old Sep 8, 2011 | 08:06 PM
I'm almost stuck!
Originally Posted by Lil Dog
The early ISBE engines in 03 and 04 had a lot of fuel rail pressure overflow valve failures. Can't remember the exact name of the part, but its the pressure relief valve for the High pressure rail. It fails and won't maintain fuel rail pressure.
Where is the overflow valve? Does it have a sensor or switch to check?
Old Sep 8, 2011 | 08:34 PM
Polaraco's Avatar
It's more involved than that
The coils are tested, they are ultrasonicly cleaned and more.
You can probably get replacements on exchange by now
Old Sep 9, 2011 | 08:39 AM
sojoe's Avatar
early 04`s were at the fuel filter. I know cause mine failed and was put in the tamk by dealer under warranty.
04.5 were in the tank however
OP -hope you solve your problem solved and easy on the (as previously posted)either, it can wreck the engine
Old Sep 9, 2011 | 08:48 AM
mattk50's Avatar
My 04.5 was on the filter cannister replaced under warranty with in tank @ approx 60,000
Old Sep 9, 2011 | 09:29 AM
papaduck's Avatar
OK, so it sounds like an injector...What is the best way to confirm this? How can I test each or all? Running a Banks six gun w/speed loader would that matter on testing or replacement injector choice?
The only test I know of is to block off each injector one at a time and see if it will start. Use the tool that can be gotten from Geno's.
http://www.genosgarage.com/prodinfo....mber=LT-TESTCA
Old Sep 9, 2011 | 10:45 AM
Rpainter's Avatar
My 04.5 had the pump mounted on the fuel filter canister
Old Sep 9, 2011 | 11:44 AM
Lil Dog's Avatar
There is a way to do an ohm check on each injector as well to test.
Search the 3rd gen area for these topics.
Old Sep 9, 2011 | 12:30 PM
Totallyrad's Avatar
They didn't go to the tank from the factory until at least 05.
It seems unreasonable that one injector would keep the engine from starting or that all the injectors went south at the same time. Lose the Banks, check all the connections and wiring first. Get the truck back to stock before trying to find the problem.
Old Sep 11, 2011 | 12:45 PM
The first thing you need to do is remove the Banks.. The chip very well could be the problem. A lot of problems are solved by simply removing programmers and chips. The computer programming in them can fail after time
Been working (27hrs. in 2 days) finally got to get back here to see some input! We have a consenus that I should have considered alsoThanks guys... Going to disable the Banks now here in the garage.
Old Sep 11, 2011 | 03:46 PM
Bypassed Banks Six Gun & Speed Loader with Banks (OEM) bypass plug for the system and the truck still cranks but will not fire up. Being "bypassed" the tuner shows "faulty fuel rail input signal" and "faulty manifold absolute psi input signal. With that said, the fuel psi on the truck should be good or it would sense a fuel psi issue when the system is fully functioning correct??? The engine...after being ran when hot or mostly warm will start but it's alot slower to fire. The Banks system being totally removed the truck only cranks.
Old Sep 11, 2011 | 05:32 PM
Rpainter's Avatar
Have you unplugged the grid heater on the pass side battery and then tried a small shot of ether into the intake?? to see if it starts??
Old Sep 13, 2011 | 03:08 PM
I bought a meter and will check the heater. Going to get an injector "plug or block-off" tool to go down that avenue as well. More to follow. Thanks again gentlemen!
