idling down
Old Feb 21, 2007 | 04:59 PM
el toro's Avatar
idling down
Of course when I'm running hard and/or loaded I idle my truck down for at least a few minutes before shutting off, but what about unloaded runs around town? Is it less of a concern now than it used to be on older diesels? I don't have an EGT gauge yet so I have to wing it. My pops has his 04 with 60K+ miles on it and he always just shuts it right down without idling. Thoughts? What do you guys do?
Old Feb 21, 2007 | 05:11 PM
Its All Good's Avatar
Not idling, I'm surprised the turbo hasn't had any problems. Without a EGT gauge I would guess 45 seconds to a minute should be ok on light drives.
Old Feb 21, 2007 | 06:45 PM
4x4not's Avatar
I have a temp-based turbo timer and during normal driving it rarely idles more than 30 seconds. If I have been running hard or towing it can take as long as 3 minutes.
Old Feb 22, 2007 | 08:14 AM
TonyB's Avatar
No load, just running around town, takes about 30-45s to cool the exhaust down to ~300-325F. This is the lowest temp I shut down at. Annoys my buddies at work when we go to lunch. I don't care...I want the turbo and the whole motor to last as long as possible!
HTH
Tony
Old Feb 22, 2007 | 12:15 PM
bdewey's Avatar
There should be in your owners manual on estimated times you should idle before shutdown. I have an EGT guage on mine and as soon I put it in Park it goes to around 300 in about 15-20 sec.
Old Feb 22, 2007 | 12:45 PM
steelblitzkrieg's Avatar
DTR Detective
Yep it's in the manual, I don't idle down after my commute, but I am also coasting into my driveway or parking spot from around the corner, so that's at least 10-15 seconds of idle cool down. If I go on a long trip 100 miles or more, I'll idle her down for a minute. I have yet to tow or haul anything substantial yet to warrant anything longer.
Old Feb 22, 2007 | 12:53 PM
djbikeman's Avatar
With my 06 (Had the Juice with turbo timer), I could come off a 200 mile run at 75mph (No trailer) and it would only idle for around 30 seconds.
Old Feb 22, 2007 | 01:30 PM
PoorMansCat's Avatar
I'm kinda lucky, its about 3/4 mile from the highway to my driveway, then abouut another 1/8 mile on my property so I just idle it into the parking space from the highway... Main thing is to get EGT's down so than when u shut down, the oil in the turbo doesn't Bar-B-Que. Tends to cause torn up seals, warped shafts, and lots of headaches.
I've actually been wondering if somebody makes a post lube accumulator for the Cummins in the event of a hot shutdown.
Old Feb 23, 2007 | 02:59 PM
el toro's Avatar
I hear ya'll and I do my best to idle it down for at least 30+ seconds (longer if on a hard run), but I know of so many diesel guys who laugh at me and just shut her right down after pulling into a spot. None have ever had any turbo problems at all.
Has anyone actually experienced a problem on a modern truck caused by hot shut down?
Old Feb 23, 2007 | 03:31 PM
ptgarcia's Avatar
Just turn it off. If turning it off was a problem you'd hear more about burned-up turbos, or Dodge would have put an EGT gauge or turbo timer in the truck. If you're worried about it after putting it in park count to 10 then turn it off.
sallyman1
Feb 14, 2008 10:43 PM
scottmn1
Jul 28, 2007 05:49 PM
silverbullet02
Sep 7, 2005 04:49 PM
Traveling Man
May 27, 2003 08:53 AM
Coco
Oct 30, 2002 06:06 PM
