Identifing factory tubo
Old Nov 26, 2007 | 12:23 PM
kylwilborn's Avatar
I just bought a 2003 Dodge 3500 it has a lot of mods I am trying to figure out if it has the factory turbo or not from the front all I can see is Holest 3 it boost to about 45psi (what does a factory turbo boost to) I think that is kind of high for factory so far from what I can tell is it has an after market exhaust manifold,smarty chip,fass fuel system,pacbrake & ? I appriciate any help, this is my first dodge THANKS
Old Nov 26, 2007 | 02:14 PM
BlueDually's Avatar
not sure what it says on a 03 factory turbo, but it should wastegate at 20 or 22 pounds, stock, up to 30 or so with a boost elbow. 44psi will kill a stock turbo, but is fine for most aftermarket turbos
Old Nov 26, 2007 | 02:54 PM
rip 112's Avatar
If its boosting 45psi and its the stock turbo you will have problems eventually, the safe limit is 35psi. You may have a different turbo, but I don't think it'll have holset on it.
Old Nov 27, 2007 | 05:00 PM
kylwilborn's Avatar
Thanks I apprciate it it does have a banks elbow on it, Is there a way to adjust the wastegate
Old Nov 27, 2007 | 10:31 PM
BlueDually's Avatar
If your thinking of the big shiny red intake horn that says banks on it, thats the wrong elbow,
there should be a little brass elbow, on the turbo, with a 1/4 inch rubber hose running from it. On that plug ther is a small hex screw, out=less boost, in=more boost (iirc)
autocar56
Feb 14, 2014 10:00 PM
Josey88
Mar 16, 2010 06:03 PM
eswelding
13
Nov 18, 2007 06:34 PM
MoparRiggan
Aug 2, 2005 10:57 AM
DZLPWR
Jan 25, 2004 01:35 PM
