i dont know what to call it
Old Nov 14, 2009 | 10:28 PM
knucklbuster's Avatar
every once in a while my 03 while under mild acceleration will act strange.
it feels like a wheel slips the truck jerks a little i noticed earlier today at the same time this happens my low fuel pressure light comes on just for a second.
no codes no cel. any ideas would you think it was fuel related? something like a weak relief valve or something. these common rails are a little new to me. the only common rail cummins im used to working on are a little bigger and come in multiples of 855 cu in.
Old Nov 14, 2009 | 11:22 PM
Purplezr2's Avatar
Low fuel pressure light, is this a stock light, I have never heard of that.
Old Nov 15, 2009 | 01:33 AM
RCW's Avatar
RCW
Before you do anything else, service the filters and make sure the bottom of the injection pump itself is not slightly damp from fuel leakage.
If that stops the trouble you are good to go, if not get the codes scanned by someone that knows what they are looking for and can read the companion codes along with the main codes, and then understands the relationship of the codes to real problems. Do not rely on Timmy Dogood the cleark at the local parts store with his discount scanner that only reads part of the codes.
Old Nov 15, 2009 | 07:15 PM
this is with new filters and the pump is dry i have modus and no codes show up.
the low fuel pressure light is an add on that most every piece of equipment i have has. it is just a light on the dash with a hobbs switch in the feed line. the light comes on solid at 6.5 psi
Old Nov 15, 2009 | 07:43 PM
05 CTD2500's Avatar
Sounds like a bad electrical connection.
Old Nov 16, 2009 | 04:12 AM
Dodgezilla's Avatar
I don't think your Raptor should be dropping to 6.5psi. That's where my stock canister mount one is under acceleration......
Old Nov 16, 2009 | 05:35 PM
i dont have the raptor on yet maybe that will solve the problem. waiting on it to quit raining. its heck to have a 40 by 80 shop and cant get your own truck in it to work on it.
bigthumper
Aug 16, 2005 08:04 AM
canucktrucks
Aug 19, 2004 06:34 PM
CCCummins
Apr 23, 2004 01:23 AM
midwestdually
Nov 18, 2002 11:30 AM
