How to Replace Tensioner
If I buy the whole assembly, can I install it without removing the radiator etc? Looks like there is just enough room, but though I would ask. Also, do 3 bolls hold the assembly? Size of head?
Yes, removing the air filter box helps, just did all of that Monday night. Be prepared to bang your knuckles up a little bit and be patient with it. More than once I got a little frustrated trying to get the bolt hole lined up.
What kind of symptoms did yall have to make you replace the tensioner? Did it go out all together or just make noise? Also what mileage are yall at? I havn't replaced mine yet and would like to know what to look for.
I'm at 137,000 miles, threw one belt last friday and left me stranded, threw another the following monday, finally got a new tensioner and all seems fine for now. Checked all pulleys, alignment, only thing I noticed on the old tensioner was a little bit of wear to one side of the plastic pulley.
My pulley started squeeling for the first few minutes after startup at about 40k miles. Replaced just the pulley and bearing much cheaper than buying the whole assembly (dayco brand from autozone, same as what is installed from the factory). If lots of miles I would replace the whole assembly.
Stainless
Mar 1, 2008 12:14 PM
banshee
23
Aug 16, 2004 02:20 PM
