How to: Remove VB
It makes a real mess as you pull the valve body out of the case. As you loosen the bolts that hold it in the fluid starts to go everywhere and there's plenty of it. I usually get a really big piece of cardboard for this operation. There are a couple of parts on top of the VB that will have to be switched over from your stock unit but that's easy. You have to pull a couple levers off before you can pull it too. Be careful with the electrical contacts inside the case.
New2ctd,
Go over to www.Dieselram.com and page Tim Holt. He's the tranny guru near you. Although he at the engineering level he will be glad to give you advice.
Good luck. If you were near Austin I would help you.
Pete
Pete
How far is Ohio from here???
Thanks Pete! I will hit him up. I want to try and do this myself for the experience of it.
The service manual makes it look like a 20 minute job once the pan is off.
RoadDiesel
Aug 7, 2012 06:06 PM
Dodgezilla
Jul 17, 2004 05:24 AM
