How much oil does the diff hold?
Cummins Guru
11.5 Rear Axle MOPAR® Synthetic Gear Lubricant SAE 75W-90 part number (5102232AA) 8.8 Pints 4.2 Liters
Filling an axle to the bottom of the fill hole may result in an over fill condition. This can cause fluid foaming which will result in inadequate lubrication to the axle components. To check axle fluid, park vehicle on a level surface. Take a piece of wire and make a 90 degree bend two inches from the end of the wire. Insert the wire into the fill plug hole and use it like a dipstick. Remove the wire and measure from the 90 degree bend to the oil level. Refer to specification for the correct measurement. Cover is marked with fill level or measure 1/4 inch below fill plug.
Cummins Guru
No new gaskets are needed for the front and rear differentials as recommended by Dodge. I wipe down the gasket and the mating surfaces prior to re-installation.
Two things I'd add...
Some of the rear ends have a "fill line" stamped about 3/4" below the bottom of the hole. I usually use an allen key as a dipstick.
Also, many of us have broken cover bolts tightening them to factory spec with a torque wrench. I'd back off from the 30 ft/lbs specified in the factory service manual.
I made a little cheat sheet for all my fluids, and filters and all that. I wrote down my rear tooks 4 quarts and front tooks 3 quarts. I remember having a little left over.
Over filling a diff is not like over filling a crank case. The gear are sitting in the oil so they will get lubed. Where as your motor oil has to be pumped to parts of the motor. That is when the foam can kill your motor, because the pump cant pick it up.
jesussaves
May 26, 2009 08:51 PM
sajigore
16
Aug 26, 2005 02:16 PM
sdgunslinger
Jan 7, 2003 12:14 AM
