How much does the 48re Auto trans hold
Old Jun 6, 2005 | 07:51 PM
sajigore's Avatar
How much Trans fluid does the 48 RE auto transmission hold? time for 30K mile maint.
Old Jun 6, 2005 | 11:53 PM
451Mopar's Avatar
I'm not sure, but it should be in the owners manual?
What type of fluid do these transmission use? Type 3 (7176) or Type 4?
Old Jun 7, 2005 | 06:56 AM
handymantim's Avatar
My shop manual says 4 QTS for a service fill and 29-33 pints for an overhaul.
Type 4
Old Jun 7, 2005 | 02:43 PM
sajigore's Avatar
Thanks for the response, Ill go for four quarts....
Old Jun 7, 2005 | 04:29 PM
451Mopar's Avatar
4-Quarts? I would figure at least twice (8-10 quarts) as much If you remove the trans pan and replace the filter, but I could be wrong since I haven't done it yet.
Old Jun 7, 2005 | 05:51 PM
guyssets's Avatar
From: Different City each Week of the Year, Currently: Newtown Ct
you better get extra...
My 02, said 4 quarts, and by the time i was done, i put in about 9 or so...
Old Jun 7, 2005 | 08:39 PM
moterhead's Avatar
I just did my '04 HO. Four quarts definitely IS NOT correct. I bought 12. Had one left. Use only ATF +4. Get it at the Dodge dealer. I paid less than $4 a quart. A pretty good price. Warranty requires +4. BTW, you only need to buy the filter. Don't buy a pan gasket. It's reuseable as is the differential. While you have the pan off, put one of the B&M trans pan drain plug kits in it. Definitely helps the next time. When you install it, don't overtighten the nut. You will ruin the nylon washer. I ruined mine. Couldn't find another so ended up brazing it in place.
Old Jun 7, 2005 | 09:23 PM
sajigore's Avatar
Thanks all, I will opt for 12 then. I did order the b&m drain plug and a filter from Genos.
Old Jun 10, 2005 | 04:22 AM
TexasCTD's Avatar
If you have the money and tow alot, you might consider putting on a Double Deep Transmission pan from Mag-Hytec or PML. They will provide more fluid (4 extra quarts on MH) to help keep temps down and they provide a drain for ease of changing out the fluid. Also, if you want to add a tranny temp gauge there is a place on them to mount the probe.
Old Aug 5, 2005 | 11:56 PM
tweeter's Avatar
I installed a double deep Mag Hytec pan on my 04 and it took 10 litres (what the hell is a quart) (eh)
Old Aug 7, 2005 | 06:38 PM
1sttruck's Avatar
As suggested in another similar thread, for the 1st service at least I'd drop the pan to clean stuff as well as doing a full flush. The way auto trannys are typically designed they don't have full flow filters, instead they seem to rely on collecting in the pan and not getting sucked up past the screen. They way they're designed they also hold a lot of fluid besides what gets replaced when dropping the pan. So, to clean the tranny and change all of the fluid you need to drop the pan AND do a full flush.
Old Aug 8, 2005 | 11:12 PM
Jmac's Avatar
I did my own drain and fill twice over the course of 45K miles. Tranny continued to shift rough. Paid Dodge dealer to do the flush. They used B&G +4 product with an additive truck shifts better than when new?!!?
I asked about the regular Mopar +4. Service guy told me other companies make it but it's not available to the public. B&G also has their own warranty on the tranny if you use their product. All of this was endored by my Dodge dealer!!!?
My .02
Jamie
Old Aug 9, 2005 | 09:06 AM
Lightman's Avatar
On my 04 when I did just a pan drop/filter change I got 6.5 quarts out.
Old Aug 9, 2005 | 10:39 AM
tcr's Avatar
tcr
Where do you get the B&G +4, never heard of it?
