?how much for after market gauges?
Your lookin' at a couple hundred bucks pretty easy for three gauges and the pillar pod.....Thats just parts, I have no clue how much it would cost to have them installed. I don't think the install is that hard just a little time consuming.
I recently installed ISSPRO's from Diesel Manor for just under $300 shipped. They are the 2 gauge kit with the A-pillar pod and everything needed to install and come with instructions that are probably better than any instructions I've ever seen.
I am thinking the Scout from quadzilla is looking a whole lot simpler than installing analog gauges. I think the price for the Scout would be a lot less than gages if paying for the installation. From what I have read about the Scout, plug'n'play...
Go GlowShift
The only drawbacks are: the wiring harnesses are very short about 12 inches, not sure if that is the norm or not for gauges as this is my first set. And the brightness is not dim able. However, on the 7 color gauges, for night time the gauge color can be changed to red numerals; so not that big an issue, at least for me.
Also, I chose the tinted black face tinted gauges. They were hard to read in the daytime due to glare until I mounted them in a pod over the mirror. So I recommend the white face gauges. if not mounted in a well shaded area.
I now have auto meter phantom gauges and really like them. They came from xtreme diesel performance. Two gauge boost, egt with pillar mount-$265.00, Three gauge boost, egt, tran. temp with pillar mount-$317.00. Also, the color on the pillar mount matches perfect. I just noticed you had a 6 speed so you could trade the tran. temp gauge for a fuel pressure gauge also.
Just my $0.02
thanks guys i think i am going with the fuel pressure for now with the factory rt gage pod from dodge. i am a little worried about the lift pump.I keep getting this darn engine light ,its driving me crazy. No one can figure out what is the deal .It is a fuel delivery code but the truck runs like a champ! I have tryed the module on the side of the high pressure pump,the rail pressure sensor ,but those two things did nothing.
FWIW, here is what Im running on my 05.
The boost, EGT I got from a local diesel shop.
The FP, isolator and tranny gauge and mounts came from here
http://www.kensperformancesolutions.com/home.html
