How many of you see moisture from the Rear pan gasket??
I posted back in january that I had a drop of oil getting ready to drip from a rear pan Gasket bolt. I snugged them all down a tiny bit and it has pretty much stayed dry ( A little moisture but no formation of the drip). Last night I had my drip forming again. I again wiped it down. I was told by Many that this was pretty much the norm, just wondering how many of you out there had seen some oil moisture from the Rear pan gasket/Bell housing area?
Not from blow by tube...
Thanks a bunch!!!
PS I started using AMSOIL 15/40 Synthetic about a month before the first time I noticed it. From what I understand the newer trucks have Gaskets that don't react to Synthetic like the older trucks did. " Used to be" that switching to Synthetic MADE leaks, but from what I hear that is no longer the case...
Truck has 21,000 miles
Thanks a bunch!!!
Should not leak.Not the norm on these engines.Might want to pull those back oil pan bolts out one at a time and put some sealanyt on them.Pan gaskets really leak.Rear main seals do.Thats also why theres engine dye and a black light.
I've had that smae problem on my two CTD powered dodge trucks as well as seen it on a lot of 5.9 powered equipement. They are know for it.
Definitely they SHOULDN't leak, yet they do.
If ur under warranty I'd take it in and gripe.
Roperteacher
Sep 21, 2007 11:07 AM
bostongsx
Sep 25, 2006 11:25 PM
Common
13
Aug 2, 2006 08:15 PM
rattle_rattle
May 18, 2004 10:46 AM
